Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Renard SS24 - Flashed chips not working
    Burlington, NC
    49
    Default Re: Renard SS24 - Flashed chips not working
    [URL="http://www.facebook.com/MapleRidgeLights"]http://www.facebook.com/MapleRidgeLights[/URL]
    2014: 4 static incandescent strings & 2 inflatables
    2015: Over 9000 pixel channels & 72 Renard channels. 3 E682 controllers, 3 Renard SS24s and E1.31 bridge. House & windows covered in pixels! 4 HDPE arches, 11ft pixel tree & star, 12 LED mini-trees, 8 LED snowflakes, 2 4' LED Candy Canes, Chroma-cane and various LED strings in trees & yard. Xlights / FPP run the show!
    2016: My CLAP is telling me to go BIGGER!
    Mooresville, NC
    7,601
    My question is, why do you keep using the "blank check" feature? It has nothing to do with what you need accomplished.
    At this point, you should pick up some new PICs and try.
    Mooresville, NC
    7,601
    Okay... here is somethings I see.............
    First, uncheck the MCLR and try a 4.9 voltage (copy my picture)
    Second, In your "Source" box, I never see the firmware loaded. look at my step two pic.
    After programming, stop, remove the pic, nothing else needs done.
    Burlington, NC
    49
    Thanks Wayne! It may be tomorrow before I can try again, but I'll try what you suggested.
    ...and I won't do a blank check!
    Burlington, NC
    49
    OK... Finally found time to try again. Success!
    I guess the problem was my fault, but it's also due to the fact that the pickit software is NOT very intuitive / user friendly.
    Here's what was happening...
    I loaded the first chip (of 6). I performed an ERASE because I read that you should always do that first. Then I clicked FILE, IMPORT HEX, and selected the Renard hex file. The SOURCE box in the pickit software showed the hex file as expected. I flashed the chip, and it was successful.
    Then I loaded the 2nd chip & performed an ERASE. However, the ERASE function caused the SOURCE box to become blank! ...and I didn't notice it when I flashed the chips in the past. Since I didn't notice, I proceeded to flash the remaining 5 chips with NOTHING! That's why I had 1 good chip, and 5 blank chips.
    So when I re-flashed them today I had to re-import the hex file after erasing, and before writing each of the chips. What's up with that? Once I load a file, it should STAY THERE! That's just crappy software IMHO.
    When I clicked ERASE, my intent was to erase THE CHIP, not the imported file! Very confusing!
    Hopefully my experience will help other people who run into this issue & find this post.
    Thanks again to all who helped!
    I can't wait to see all the kids' smiling faces when the lights are shining brightly!
  6. Likes TazChaLet liked this post
  7. #16
    Mooresville, NC
    7,601
    Here is the deal, if you read the instructions of the pickit, it does an erase before it does the write on it's own. ;) So no need to add the steps you have been adding. Following my video verbatim would give successful results every time.
    Glad you got it done.
  8. Likes TazChaLet liked this post
  9. #17
    Gaithersburg, MD
    225
    Hi Rob,
    I am preparing to do the same and your notes are great! Thank for the intel.
    2016 Migrating to Vixen 3.2
    Vixen 2.5x
    120 Channels
    2015 5 RenardSS24 @ 20,600 lights
    2014 5 RenardSS24 @ 18,600 lights
    2013 3 RenardSS24 @ 9,900 lights
    2012 2 RenardSS24 @ 6,000 lights
    2011 began researching
    [url]www.KentlandsChristmas.com[/url]
  10. #18
    Burlington, NC
    49
    Quote Originally Posted by MikelMD View Post
    Hi Rob,
    Cool! Glad it helped! My Renards are still running strong after finally getting the chips flashed, so hopefully that will be a simple task for you.
