Results 1 to 6 of 6
Thread: I need help with Light sequence speed, I need to increase the speed
    Oct 2015
    Seguin TX (out side of San Antonio)
    3
    Default I need help with Light sequence speed, I need to increase the speed
    Hello
    I built a light sequence using HLS (my first one). Its just pixels chasing to a beat.
    But, I need the to move faster and continue to the end after the beat stops.
    Its laser shooting sound and the lights need to move faster, and not disappear after the sound stops (chase to the end).
    I'm using LED Strip Lights (WS2811) 300 pixels per string, 3 strings (900 pixels).
    This is for a Halloween display.
    Mike
    Jan 2013
    California
    238
    Default Re: I need help with Light sequence speed, I need to increase the speed
    Light 5/10/15 led's at a time.
    6,081
    Quote Originally Posted by dwcbinky View Post
    Hello
    Mike
    There is a few things you can do for speed .
    use a sequence timing of 25msec
    shorten the duration between each effect/rgb channel <Note >
    1 time tic between each is the fastest you can go
    If you want lights to chase and stay on you will need to use the fill feature within HLS .
    Oct 2015
    3
    3 led's at a time, ramp down.
    Mike
    Oct 2015
    3
    Can you change the timing after the sequence is built, when I chick on timing (Time Resolution) it says it can't be changed, its set at 50ms.
    Is there another place I can change it.
    I don't know how to use the fill channel, is their a video or tutorial on it.
    Mike
    Aug 2012
    Nova Scotia, Canada
    1,684
    For lights to chase and stay on you can use the background/foreground effects.
    You have to ensure the channels you want to use both have Backgrnd box checked in manage channels first.
    Once done, you can select background only and then fill that in with a solid color (usually less intensity like 20 or 30%).
    Switch to foreground/background in effects and add the desired chase.
