Results 11 to 20 of 29
Thread: Ac SSR issue
    Morrisburg, On, Canada
    2,540
    Default Re: Ac SSR issue
    A red LED has about 1.8V when conducting, so that appears to be normal, assuming the opto internal light is a red LED.
    Under this voltage 1.8V condition, the output triac should be turned on as well.
    Not sure about the "transistor" side. Are you referring to the opto? If so it is a triac.
    You could also populate the 2nd channel and see if the operating symptoms are the same. Then use that channel to troubleshoot the bad channel.
    Sep 2013
    Newhaven, East sussex, uk
    437
    I am referring to the output side of the moc3023.
    I will be constructing the other side of the board to see how it goes. Hopefully its just a flaw in the PCB mmanufacture process which can happen from time to time.
    80+ plus channels
    2 x 32 channel custom build tlc5940 dimmable DC controllers.
    1 ren 48 LSD v3c
    All rgb strips and 1 custom made face.
    2,540
    Quote Originally Posted by masterful View Post
    I am referring to the output side of the moc3023...
    Yes, that output is a triac built inside.
    Sep 2013
    437
    Oops sorry thanks for correcting me
    80+ plus channels
    1 ren 48 LSD v3c
    2,540
    One way to test the MOC is to connect a load to its output, consisting of 2 LEDs wired "back-to-back" plus a series 620 ohm 1/2W resistor to a 12VAC transformer.
    The LEDs should dim with your MOC input PWM.
    Sep 2013
    437
    Thanks for that I might give it a try.
    80+ plus channels
    1 ren 48 LSD v3c
    Sep 2013
    437
    OK still hiting my head.
    Built 2nd channel. Same thing happening as first channel.
    Should I try reducing the resistor on the gate.
    I know for 230volt it should be 330ohm.
    80+ plus channels
    1 ren 48 LSD v3c
    Sep 2013
    437
    I'm using the bta04-700trg triac
    I do have the bta06-600cw as well
    80+ plus channels
    1 ren 48 LSD v3c
    Sep 2013
    437
    Hi there. I think I need to try a different triac and opto.
    I read in another post about moc3023 from different manufacturers not performing. Think that's my next step.
    Any thoughts great
    80+ plus channels
    1 ren 48 LSD v3c
    2,540
    I don't understand that statement; " moc3023 from different manufacturers not performing".
    If you are operating within the specs there is little to go wrong.
    Has your board been known to be a working design?
    There are no solder joint problems?
    Your outputs are wired correctly to an AC source?
    The MOC's triac is basically a switch to pull the output triac's gate high through a small resistor. You could emulate that with a toggle switch designed for your AC voltage. Again, a safe means to conduct such a test is warranted.
