Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Exported sequences drop out after about two minutes
    43
    Default Exported sequences drop out after about two minutes
    I'm having some trouble with my exported sequences. This might be the same problems others have been having, I'm not sure. When I export to FPP and play back my sequences, which are about 3 and 4 minutes respectively, they won't play all the way through. They both stop somewhere near 2 minutes, and they both stop at the exact same place every time. I have watched Vixen in the Task Manager during export, and by the time it's done it's using 5 or 6 GB or RAM, but I have 16GB so that shouldn't be the problem. I have 3795 channels, all RGB pixels, going to two Pixlite 16 controllers. I'm running Windows 8.1 on a 2015 Core i7 laptop.
    Maryville, Illinois
    1,609
    Default Re: Exported sequences drop out after about two minutes
    Can you better define stop playing. Do the lights go dark or freeze? Is it just some of the lights? Does it do it on a fresh start with the first sequence or subsequent exports? Is it all exports of just some?
    Any details you can provide may be helpful.
    Jeff
    43
    It is all of the lights, and they go dark. So the whole house goes dark all of a sudden.
    I only have two sequences that are more than two minutes long so far, and it happens on both of them. I'm not sure if a fresh start affects it. I will test and find out for you.
    43
    I just re-exported both songs after restarting the computer, and this time the first song I exported plays all the way through, but the second goes all-black after around a minute.
    The first song is Ghosts n' Stuff, and the second is This is Halloween. Here are links to both newly exported sequences, and to a zip of my profile (without media):
    Ghosts n' Stuff FPP (works)
    This is Halloween FPP (doesn't work)
    My Profile
    Winter Haven Florida
    3,039
    try too export 1 then close down and reopen and try the second think I seen someone say they had that problem I didn't myself
    James WinterHaven Fl
    7,754
    Are you guys who are seeing this problem on a .net newer than 4.5.2? I may be getting my issues mixed up but I think this is related to the newer .net framework. If you're on win 10 you're stuck with 4.6.
    --Jon Chuchla--
    Rogers, AR
    54
    Running .NET 4.5.2 here on windows 7 home ultimate.
    Maryville, Illinois
    1,609
    Quote Originally Posted by BigAlsTwinkle View Post
    Can you describe the behavior you see as well?
    Adelaide, Australia
    166
    This behaviour was reported in VIX-849
    Dave
    [SIGPIC][/SIGPIC]
    Aug 2012
    Charleston, SC
    1,088
    I experienced this as well when testing my sequences last night. The lights would stick in certain spots However, I thought it was related to Google Drive sync issues (I use Google Drive for my Vixen profile, which probably isn't a good idea). The issues were with sequences exported from a Win7 64bit machine. I re-exported from a Win7 32bit machine and they were fine.
    Something else you may want to check since FPP is in the picture - make sure your updated sequences are actually uploading. From the file manager web interface, check if the timestamps are updating. For some reason, my USB drive had the FAT32 dirty bit set and was mounting read-only. It somehow had gotten corrupted on a reboot or power cycle. I'll submit a ticket for FPP on it, as there was no indication that the files weren't been written.
    [url=http://www.youtube.com/playlist?list=PLY6l3Fd1SM8viL-Q76DVHtjltwR6XbOc7]2014 Christmas Videos[/url] - [url=http://diychristmas.org/vb1/showthread.php?3261-Candlewick-Lights-2014-video-and-details]Write Up[/url]
    [url=http://www.youtube.com/playlist?list=PLY6l3Fd1SM8sTEvf6hIhPJX9rWgfbSmRX]2013 Halloween Videos[/url]
    [URL="http://diychristmas.org/vb1/showthread.php?1255-Generic-Dongle-HSXP-2108G&p=15008&viewfull=1#post15008"][COLOR="#FF0000"]Warning on cheap USB RS485 dongles - You get what you pay for...[/COLOR][/URL]
    [URL="https://github.com/forkineye"]My GitHub Stuff[/URL] | [URL="http://kw4fb.com"]My Ham Radio Stuff[/URL] | [url]http://forkineye.com[/url]
