Thread: Which DCSSR to get? Dumb RBG strip.
    Jun 2007
    Ontario, Canada
    2,438
    Default Which DCSSR to get? Dumb RBG strip.
    Greetings
    I have 2 feet of dumb rgb strips in my North pole for lighting.
    +12v
    B
    R
    G
    is the wiring layout.
    +12vdc is COMMON and the ground wires run independent for each colour, THIS IS OPPOSITE to how a typical SSR is built where ground is COMMON.
    Not pixel strips, just dumb 12vdc 5050 leds with resistors..
    Which DC SSR should I be looking to buy?
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
    Chat link | Christmas Wiki link
    Oct 2008
    San Jose, CA
    10,282
    Default Re: Which DCSSR to get? Dumb RBG strip.
    No - - the typical DCSSR is common anode (common +) and the MOSFETs sink the ground from each color.
    Brian
    Christmas in San Jose! on Facebook
    Richardson, Texas
    363
    So on a DC SSR like this, would you run a jumper wire from the + out to the other + outs and then connect the R,G, and B to the - outs.
    I have to admit I'm a little confused about this as well.
    Oct 2008
    San Jose, CA
    10,282
    I'm not completely familiar with the DirkCheap SSR but I think you'll find it's the same as the DCSSR and the input +DC is the same connection/trace as the + on the RGB outputs and are already connected together. A quick look at it visually and/or with a meter should tell you that.
    Brian
    9,633
    You'd provide +/- power at the DC IN terminal block. Then you have four channels of output, and the + signal is common to all four channels while the - is switched. You would want to use common anode strips with this SSR.
    http://digwdf.org/store/
    Even though the DIGWDF Store has been closed for almost five years, it's still awesome!
    Chambersburg, PA
    1,356
    Quote Originally Posted by CatMan42 View Post
    In answer to the OP's question. I would recommend one Dirk's Cheap DC SSR's like shown above. You can get them @ http://digwdf.com/store/category.php?id_category=9 . He has two different versions available, one is capable of handling higher amperage.
    2016 - No Display
    Richardson, Texas
    363
    Ah Ha!! that makes sense. Thank You.
    Aug 2012
    Nova Scotia, Canada
    1,948
    Would a DM-103 work, you could embed this into your prop (they are very tiny).
    http://www.aliexpress.com/store/prod...868042910.html
    I believe RobG has alternative firmware for this tiny board as well (to run some DMX floodlights).
    I bought 10 on my last order from Ray, but doubt I am going to use them all this year.
    Jun 2007
    Ontario, Canada
    2,438
    Budude, on closer examination of my DC SSR, you are correct! re-wiring my connection and testing..
    Edit**
    Forgot to reply after testing..
    Everything is working.. I had my SISO board incorrectly wired to my Ren8SS
    Cheers!
    Steve
    My weather today
