Actual I did but they got missed on the first proto board you did. I missed them because the first testing I had done was full current to see if the leds would survive. I solder them to the bottom and still have that board. I asked you to add the resistor spots after that. you changed the resistance I suggested afterwards from my suggestion and so my personal controllers run a little less current than what the rest of you are, but if the leds don't die to fast its not a problem. In fact if you look at the how to on computer christmas and look at my board that pre dated the much nicer ones you laid out you can see the resistor is there.
