Results 11 to 20 of 25
Thread: External Power Supply Info
    Stockton, California
    49
    Default
    Quote Originally Posted by teberle
    David,
    Not all power atx power supplies are huge. what size are the approx. dimensions needed.
    See photograph below
    49
    Default
    Quote Originally Posted by Macrosill
    David,
    I purchased a 5v psu from ebay for around 15.00 shipped.
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=170115611542
    Hi Brian,
    Wouldn't a psu like this work (see attached picture & data sheet)??
    These make good bench supplies, because they:
    1. have a monitor LED that's visible from the top
    2. have an on/off switch
    3. don't require any minimum load like PC power supplies do
    4. have good regulation (±1% line, ±5% load)
    5. have good efficiency
    Attached Files Attached Files
    Apple Valley, MN
    3,768
    Default
    They also:
    1. Don’t need a fan.
    2. Semi water resistant
    3. Are more astatically pleasing
    </div>
    Long Island, NY
    7,690
    Default
    David,
    That would work fine. Just be sure that it meets the power requirements for the Ledtriks panel.
    Melbourne, Australia
    1,079
    Default
    I have not measure the Panle at 100% LED on, but I would be shocked it the current draw was more than 3 Amps. Anyone put a Multimeter on their panel yet? to test the load current in operation.
    John.
    [B]John[/B]
    [url]www.xmasinmelb.com[/url] General Site
    [url]www.xmasinmelb.com/zencart/[/url] Online Store
    [SIGPIC][/SIGPIC]
    49
    Default
    David,
    I couldn't find any information on the power requirements for the LEDTRIKS;
    P = v * i
    = 5v * 3A
    = 15 W
    Does anyone have (or measured) the load current when the panel is on? Does it draw anything near 3A at +5V?
    David
    Long Island, NY
    7,690
    Default
    I believe the "fully on" power consumption is about 4 amps. That is a worst case scenario if for some reason things locked up and all the leds came on and stayed on.
    Battle Creek, MI
    20
    Default
    Quote Originally Posted by wjohn
    John.
    I got about 840 milliamps with 100% of the LEDs on. When I was running some text across the board, the current varied between 50-200mA.
    Michael
    Waterboro Maine
    1,020
    Default
    I’m not one to question someone’s results but....
    RJ posted in his how-to over at computer Christmas
    On page 2 that the board Can use up to 4 amps
    This may happen if the Pc locks up or freezes and the leds are
    No longer being refreshed at 80 plus times a second so remember
    There are things going on during the operation of the panel that
    Most are not aware of such as the leds are being driven with much
    More current than they are designed for but only for 1/16 duty cycle
    ( I believe they are 20ma leds and they are driven at 80 ma at 1/16 duty cycle)
    Any questions about power consumption of the ledtriks should be forwarded to RJ directly
    when in doubt ask the guy who developed it.
    Avon Park Florida
    672
    Default
    I would say you will be fine. When I first built the board I pushed it much harder than I let you guys to see when it would start killing Leds. Then I turned the current down for the best compromise I could get between not killing leds and brightness. Before we turned the current down the panel had a peak of 4 amps for a couple of microseconds just as the switching happend. You power supply would not mind this as the output caps will absorb it. After the peak it would fall to around 1.5 amps. After that we dropped the current so its well within you p/s capability. So have fun!
