Page 11 of 17 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 165
Thread: ESPixelStick Group Buy - E1.31 WiFi Pixel Controller kit
  1. #101
    2,599
    Default Re: ESPixelStick Group Buy - E1.31 WiFi Pixel Controller kit
    Got mine today. Now I need to add more elements. Oh and that means another power supply and more strips and...
    Thanks for getting this together.
    Martin
  2. Thanks sporadic thanked for this post
  3. #102
    South Jersey
    2,004
    Got mine!!! Thank you!!
    Sent from my XT1254 using Tapatalk
  4. Thanks sporadic thanked for this post
  5. #103
    North Richland Hills TX
    557
    Removed by poster, went back and reinstalled everything. Problem resolved.
  6. #104
    Sep 2007
    Houston, TX (Clear Lake)
    267
    Thought I had seen this addressed in some manner, but not finding it now... maybe on another forum?
    Somehow, one of my sticks got set to the wrong subnet (192.168.9.104 instead of 192.168.0.104). I'm certain it wasn't user error...
    So... how can I get it completely reset? I re-uploaded the firmware, but those settings must be stored elsewhere - it's keeping the incorrect IP, as seen in the serial monitor.
  7. #105
    557
    I had the same issue and used my show router to be set to the subnet then made the changes necessary to set both of them back correctly.
  8. #106
    South Jersey
    2,004
    I have a question. When I use GECE's with this the UI gives me a choice of RGB BRG etc, but it wont let me save it, plus according to my E682 the order for GECE's is BGR, which I don't see.
    Nevermind Setting it to GECE works just fine.
  9. #107
    Aug 2012
    Charleston, SC
    1,041
    Quote Originally Posted by blake_l View Post
    Quote Originally Posted by stampedeboss View Post
    I posted about it here - http://doityourselfchristmas.com/for...788#post397788. That should get it reset for you. That also reminds me that I was supposed to go back and check on static address issues (I use DHCP myself). Let me know if you have any issues with it.
    Quote Originally Posted by scootchu View Post
    Oh yeah, GECE ignores whatever the color order field is set to. It just expects normal RGB from your sequencer and will output in the correct GECE order.
  10. #108
    Florida
    896
    Just as an FYI The next version of the firmware will allow you to get back into the Web interface after a bad configure just by unplugging you AP and power cycling the ESP module. It will come back in SoftAP mode with a hard set address and of 192.168.4.1
    Sent from my Nexus 5X using Tapatalk
    www.billporter.info
    2014 Christmas: 1 Channel; a new house and a crazy plan.
    2015 Halloween: 2500 Channels; 3 songs. Christmas: 4500 Channels; 6 songs. Custom Wifi Pixel/Renard Controllers
    2016 Halloween: 6500 Channels; 4 songs. Christmas: 11,000 Channels; 4 songs.
  11. #109
    Sep 2007
    267
    Quote Originally Posted by madsci1016 View Post
    Unless I'm misunderstanding this (entirely possible...) - wouldn't it be better to default back to DHCP? Otherwise, you'd still have to reconfigure a router to fix it.
  12. #110
    Robbinsville, NJ
    1,534
    Got Mine! Thanks. Quick question on the arduino configuration. When I add "http://arduino.esp8266.com/stable/package_esp8266com_index.json to the additional board URLS and go to Board Manager, it does not show up. I did notice that the new version of Arduino is 1.6.6. Do you only support 1.6.5? Or is there some other reason the board is not showing up in the lists to install?
    UPDATE: I downgraded to 1.6.5 an it doesn't work either. I get a Downlaod
    Michael
    Gotham Beat Productions LLC
