Page 51 of 95 FirstFirst ... 41495051525361 ... LastLast
Results 501 to 510 of 950
Thread: ESPixelStick - E1.31 WiFi Pixel Controller
  1. #501
    947
    Default Re: ESPixelStick - E1.31 WiFi Pixel Controller
    I think this line has an extra comma
    begin(e131_listen_t, uint16_t&, int)
    Check the source again or compare to other versions of the code.
  2. Thanks qawsed55 thanked for this post
  3. #502
    Sep 2015
    Donbass, USSR
    31
    Thanks!
    I know about power needs for strips and about max current for PINs of ESP )
    About two years I learning neopixels. I'm not programmer and it is sad. I tryed many arduino scatches and ESP8266 firmwares. Some one works, some - not.
    I have installed libraries and file uploader.
    I'll check - does libraries are last versions or not.
    I have check connections. I dont know why - but one connection was brocken. If I touch - it works, but I cant see any troubles with 60x magnification. After reassembling- my matrix works with subj, but there are too many flickers. Capasitor 470mF 16V dont help. With resistor 470 Ohm on data-line - just about 15 leds light up. I'll try another signal generator or power supply (for now I`m powering led strip from PC, ESP - from USB from same PC).
    Thanks for your help
    In attachments - there are my matrix.
  4. #503
    947
    First thing I check for flickers is do I have my grounds connected correctly. Power and controller need to share the same ground.
  5. #504
    UK S80 postcode
    1,317
    Hi, not sure whether you did or not but the ESPixel code need the CPU speed to be set at 160MHz. Not doing this can cause flicker and not all LEDs to light.
    Arduino IDE -> Tools -> CPU frequency -> 160MHz.
  6. Thanks qawsed55 thanked for this post
  7. #505
    Royersford, PA (Philly)
    1,390
    I got my order today!
  8. #506
    Nov 2013
    North Carolina
    1,511
    Got mine today,thanks Shelby.
    (1) Falcon F16V3
    (1)E682
    (1)Renard SS24
    (1)E1.31 Bridge
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    (12)ESPixel Sticks (shelby aka sporadic)
    WIKI
    Become A Supporting Member
    Falcon Christmas
  9. #507
    Robbinsville, NJ
    1,535
    Got mine too... Thanks!
    Michael
    Gotham Beat Productions LLC
  10. #508
    Oct 2016
    22
    Me too, thanks a million!
  11. #509
    Oct 2016
    56
    Have they all been shipped? Haven't gotten an email yet.
    Sent from my SM-G930T using Tapatalk
  12. #510
    1,390
    I never got an email either, but keep in mind that is a lotta work to send out each email. Keep an eye on your mailbox!
