Page 44 of 96 FirstFirst ... 3442434445465494 ... LastLast
Results 431 to 440 of 958
Thread: ESPixelStick - E1.31 WiFi Pixel Controller
  1. #431
    189
    Default Re: ESPixelStick - E1.31 WiFi Pixel Controller
    For those that use a bunch of these in your displays... How are you handling power? One PSU to multiple ESPixelSticks?
  2. #432
    Folsom, CA, USA
    1,772
    Quote Originally Posted by TheLost View Post
    Yes, but smaller PS at multiple locations. I also use some small 2.5A 120V-5V dedicated PS. They fit nicely in 2" PVC conduit with the ESPixelStick.
    In Lights Therapy
  3. #433
    Gainesville, FL
    230
    I used 21 of these last year. I had one with some power output issue that didn't work, so I'm buying a few more for backup. Talking with Shelby, he thinks that 20 is about the max depending on your access point capabilities and how many wireless devices it can handle. I actually ran them on my home network with my laptops/ several cellphones/ etc inside a concrete block house. With little to no problems.
    For power- basically, it was power supply to distribution board and power wire to ESPixelSticks. For smaller things. It was extension cord to small power supply to ESPixelSticks. I thought it made the wiring extremely easy, like you would run power for your incandescents. No data wires. ... so here's a few pics thrown together to show wiring... no remember, each one can control 4 universes 680 pixels... the most I had on one was 300.
    400 watt power... to distribution board to ESPixelSticks to props....
    Running (3) E682's (1) Falcon F16v3 (1) Falcon pi-cap (20) ESPixelSticks - 8000 Pixels - Vixen - Falcon Pi Player - http://www.facebook.com/GainesvilleXmasLights
  4. Thanks TheLost thanked for this post
    Likes TheLost, zaker liked this post
  5. #434
    Nov 2014
    279
    small PS in PVC pipe? exactly what I wanted to do. Do you have a link for the PS you used?
  6. Likes pmcpa liked this post
  7. #435
    Nov 2013
    Morganton,North Carolina
    1,596
    Quote Originally Posted by -bernard- View Post
    I would also like to see this.
    Sent from my SCH-I535 using Tapatalk
    (1) Falcon F16V3
    (1)Renard SS24
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Become A Supporting Member
    Falcon Christmas
  8. #436
    Phoenix, AZ
    152
    I thirdly would like to see what power supplies you found that will fit in PVC tube. Quite a demand here, it looks like you may be onto something good!
    On this note, it looks like you used some purple primer & PVC glue on the end caps. Did you find this absolutely necessary for moisture proofing, or would a friction/slip fit suffice? What are your thoughts on some silicone sealer or hot glue around the *outside* of the joint so as to still make it accessable should you ever need to get in there?
  9. #437
    2,381
    Another interested one here. Would love to have a power supply that fits inside a 2" PVC.
  10. #438
    Folsom, CA, USA
    1,772
    Here you go.....
    These are salvaged units. You will need to remove the cut off leads and replace with your own.
    They are cheap and clean up nicely.
    Picture of one I just finished cleaning.
    They have in 12V too. Gotta order a few of those myself. I like the 3000MA design best.
    5V Sample ebay items
    http://www.ebay.com/itm/142168265195...%3AMEBIDX%3AIT <<== On Holiday til 1/31/2007
    http://www.ebay.ca/itm/AC-DC-5V-2-5A...YAAOSwAPlXh1W-
    http://www.ebay.com/itm/1PC-AC-DC-5-...a1-eYJkYj-V80A
    12V sample ebay items
    http://www.ebay.com/itm/AC-DC-12V-Sw...S9_RpdWJXpLXzA
    May want to buy some of this larger size heat srink . . . but don't shrink on too tight
    http://www.ebay.com/itm/PVC-Heat-Shr...-WiuXjkUVfYHdw
    One last work. Many sellers are on Chinese Holiday til 1/31 or some til 2/6
    IMPORTANT....One more thing. When you build, do not enter or exit the 120V end with your low voltage. 120V in one side and LV out the other.
    Do not cross 120V with 12V leads within the pipe.
    In Lights Therapy
  11. Thanks Kev7274 thanked for this post
  12. #439
    Nov 2013
    1,596
    Interesting. May have to try a few 12v 3000MA versions out.
    I believe one 3000mA version would run one string,right?
    (1) Falcon F16V3
    (1)Renard SS24
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Falcon Christmas
  13. #440
    Gainesville, FL
    230
    Default ESPixelStick - E1.31 WiFi Pixel Controller
    Quote Originally Posted by Scoobysnacks View Post
    I used the pvc glue on the one (lower) end (just cause I had some laying around) I didn't use any glue on the end cap with the ESPixelSticks attached - that cap (upper) - I drilled two holes for my pigtails - one (in) for the power wire and one (out) to pixels. Then I hot glued on the inside and outside around the wires... attached wires to the header plug - so ESPixelSticks are removable if the need arises.
    So with these hanging outside the rain hits the top wires runs off past the unglued joint and hits the lower glued joint - I didn't want water seeping in from the lower end cap. Friction holds on the top cap.
