Page 38 of 94 FirstFirst ... 2836373839404888 ... LastLast
Results 371 to 380 of 933
Thread: ESPixelStick - E1.31 WiFi Pixel Controller
  1. #371
    Jul 2007
    87
    Default Re: ESPixelStick - E1.31 WiFi Pixel Controller
    Ok, so a few things:
    Your "unicast" is basically TCP. If e1.31 unicast is indeed implemented with no-ack, it uses optimistic delivery. That means the sender assumes the packet got there ok and will not resend the packet unless it hears otherwise. A no-ack packet is a packet that a client sends back to the sender with essentially a list of packets it believes it did not receive. In your analogy, that means you'd send a reply back to the sender which contained a list of letters you were suspicious never got delivered.
    I appreciate the explanation but I didn't need the analogy :-P. I was asking about specifics of the protocol. I'm not clear why a unicast e1.31 would ever want reliable transmission. By the very nature of DMX, at some point you are going to be retransmitting packets that are out of date for the current timing frame. If multicast e1.31 is indeed more reliable over 802.11 (which I still find hard to believe as a multicast frame is sent first as an acked unicast frame to the AP and then rebroadcast as a multicast frame by the AP), why not just remove the no-ack requirement in the protocol? Transmission would revert to best effort (just like multicast) but you'd still get the routing benefits of a unicast frame.
    Might have to read the protocol tomorrow after my morning cup of coffee.
  2. #372
    Jul 2007
    87
    It has nothing to do with e1.31. And it has nothing to do even with UDP vs TCP. This is an 802.11 wifi thing. It's not at the protocol layer, it's at the transport layer. That's a lower level mechanism that's in play regardless of the protocol and application layers on top of it. This is something we have no control of from our side of the picture. It's inherent to how WiFi works. So long as we're using regular WiFi equipment , it's something we need to work with.
    Ahh, yes I forgot about the inherent ack in the 802.11 side. That also explains why you don't see slowdowns on the wired side. A multicast frame over wifi is a unicast frame until the AP transmits it. Go it.
  3. #373
    Robbinsville, NJ
    1,534
    It seems better now that I converted them to Multicast. Also, I saw reference to 2.1 code? Where/how do you get that code? Github is still 2.0
    Michael
    Gotham Beat Productions LLC
  4. #374
    Folsom, CA, USA
    1,496
    Quote Originally Posted by michaelc View Post
    V2.1 look at post 333 of this thread
    In Lights Therapy
  5. #375
    Dec 2015
    105
    Any scheduled group buy for these for 2017?
  6. #376
    Aug 2012
    Charleston, SC
    1,043
    Quote Originally Posted by wingrunr View Post
    E1.31 is strictly UDP. At the 802.11 link layer however, all unicast packets are "reliable" - ACK'd at the link layer. This can cause buffering and lag across the whole show if one node has an issue. Multicast 802.11 packets are handled much differently. They'll "broadcast" at a rate dependent upon the slowest node connected to the AP. If you have a power conscious device, like a phone, laptop, tablet, etc... connected to the same AP, the effects can even be worse. 802.11 has flags for handling devices which like to sleep and can further effect how the AP handles multicast traffic (even slowing it down to the DTIM interval).
    Now.... to really muck things up, some AP manufactures like to get fancy with multicast. Enter Ubiquiti's "Multicast Enhancement"... This will attempt to segment the traffic using IGMP snooping and transmit at higher rates that those devices support and makes multicast "reliable" - that means link layer ACKs and buffering again.. which means its really just taking your multicast traffic and converting it back to unicast which gets us right back to where we were before. For 802.11 multicast to work in our shows, it has to be in its purest form with no devices setting the 802.11 power saving flags.
    What makes e1.31 via multicast more reliable for shows isn't from a data perspective, but from an observers perspective. People will never notice some dropped packets (up to a threshold of course), however they will surely notice lag spikes and timing issues if the AP has to retry and buffer unicast transmissions too much. Many packets may die a short unfulfilled life, but its ok up to a point
  7. #377
    Aug 2012
    Charleston, SC
    1,043
    Quote Originally Posted by Not My Monkeys View Post
    I plan on starting one soon, probably this week.
  8. #378
    Jul 2007
    87
    Default ESPixelStick - E1.31 WiFi Pixel Controller
    Right. Realized that after it was pointed out the 802.11 layer was the culprit. I was thinking wired.
    I'm curious if setting ack timing to 0 on a dd-wrt router (which disables ack on Broadcom hardware) will allow the best of both worlds.
  9. #379
    Aug 2012
    Charleston, SC
    1,043
    I don't think that really disables it does it? When I looked before, all the references point to it as more of an ACK delay modifier to support long haul links. I had originally looked into hacking on OpenWRT to bypass the ACKs, but it looks like the juicy parts required are in closed source drivers for the vendors chipsets.
  10. #380
    Jul 2007
    87
    From my reading it depends on the build and chipset. Recent builds disable on Broadcom and set to auto on Atheros. I'm planning on running some tests tonight so I guess we will find out.
