Page 3 of 89 FirstFirst 123451353 ... LastLast
Results 21 to 30 of 890
Thread: ESPixelStick - E1.31 WiFi Pixel Controller
    Aug 2012
    Charleston, SC
    1,040
    Default Re: ESPixelStick - E1.31 WiFi Pixel Controller
    Quote Originally Posted by stampedeboss View Post
    Updated with the current version from GIT, now all's I get is the following on both of the units:
    Sketch uses 332,676 bytes (76%) of program storage space. Maximum is 434,160 bytes.
    Global variables use 54,440 bytes (66%) of dynamic memory, leaving 27,480 bytes for local variables. Maximum is 81,920 bytes.
    /home/aj/.arduino15/packages/esp8266/tools/esptool/0.4.5/esptool -vv -cd ck -cb 115200 -cp /dev/ttyUSB0 -ca 0x00000 -cf /tmp/build2909744127847050761.tmp/ESPixelStick.cpp.bin
    esptool v0.4.5 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
    setting board to ck
    setting baudrate from 115200 to 115200
    setting port from /dev/ttyUSB0 to /dev/ttyUSB0
    setting address from 0x00000000 to 0x00000000
    espcomm_upload_file
    stat /tmp/build2909744127847050761.tmp/ESPixelStick.cpp.bin success
    opening port /dev/ttyUSB0 at 115200
    tcgetattr
    tcsetattr
    serial open
    opening bootloader
    resetting board
    trying to connect
    setting character timeout 0
    done
    setting character timeout 1
    done
    espcomm_send_command: sending command header
    espcomm_send_command: sending command payload
    trying to connect
    done
    done
    trying to connect
    done
    done
    resetting board
    trying to connect
    done
    done
    trying to connect
    done
    done
    trying to connect
    done
    done
    resetting board
    trying to connect
    done
    done
    trying to connect
    done
    done
    trying to connect
    done
    done
    warning: espcomm_sync failed
    error: espcomm_open failed
    Nothing in the source would cause that. What are you using for a programmer? You seeing anything in the serial monitor when resetting or entering programming mode? Boards powered?
    North Richland Hills TX
    557
    Here's the interesting part, works on windows not on linux. Everything else is the same. Got 1.3 loaded and testing. Working well.....
    Aug 2012
    Charleston, SC
    1,040
    Are you running Linux from a VM or native? I ran into issues keeping a good serial connection with my Kali VM in Virtual Box, but it was solid on my bare metal machine.
    557
    Native, actually my windows is running in a VMWARE machine.
    Aug 2012
    Charleston, SC
    1,040
    That's odd. I was thinking my issues were VirtualBox related. What distro are you on what's the chipset of your adapter? I was using the CP2102 on my NodeMCU. Kali 2.0 from a VM and Kali 1.0 native. Both Debian based. Sounds like it may be an issue with the ESP flash program and newer Linux releases.
    557
    Ch340 chipset
    Cambridge, UK
    203
    I was just wondering if anyone has tested ESPPixelStick with more than 1 universe(Multicasting), at any speed.
    I am using V1.3, It works quite well upto 170 Pixels. As soon as I go over 170, it becomes really slow at refreshing.
    Reading the Forkineye / Github site, it claims 4 Universes and 25ms refresh, but I am getting more like 500ms - 1s.
    4 Universes show be more than achievable, based on the 800KHz/24bits/680Pixels = 49Hz ish
    Any help, most appreciated.
    Aug 2012
    Charleston, SC
    1,040
    Quote Originally Posted by m1anh View Post
    Multicast is only supported for a single universe and you need to be on a dedicated network or it will fall back to your DTIM rate if any devices with power management connect. Sounds like your e1.31 source maybe be wireless as well. Can't do that or you'll get all sorts of lag due to the simplex nature of wifi.
    Western Washington
    206
    Quote Originally Posted by sporadic View Post
    I've been curious about this question. I haven't tried yet, as right now I'm worried about getting all my GECE stuff going (I'll only be driving 62 Pixels per PixelStick) but exactly how would you connect more than one string of 170 Pixels for a second universe on the ESPixelStick? Photos? Or am I missing something?
    One more question, I know that these are e1.31, but is it possible to run Renard over these as well with code changes?
    Aug 2012
    Charleston, SC
    1,040
    Quote Originally Posted by AuburnLights View Post
    You just chain them together, one big strings of 680 pixels. As for Renard, do you mean for output? madsci1016 has support for it in his fork here. I'm planning on pulling his changes into the main branch, just haven't had time to work on it yet.
    As for an example of multiple universes, my test matrix is made out of 720 WS2812 nodes, connected as one continuous strip:
