Results 31 to 34 of 34
Thread: Vixen 3 - Recall of window positions
  1. #31
    Delafield,WI
    249
    Default Re: Vixen 3 - Recall of window positions
    The pc has a q6600 processor (quad core 2.4) and 6GB ram. The sequencing up until yesterday worked fine. I think I'll try an uninstall and reinstall tomorrow. I'll leave it alone today because I'm going to display the lights I just finished, tonight. I'll let you know what happens. Thanks for all the help! Much appreciated.
    Roger
  2. #32
    7,961
    That's a pretty old computer. (2007 design) you've obviously reinstalled windows at least once because windows 7 didn't exist yet when that machine was built. Depending on how long your windows installation has been running, it may be begging for maintenance or even a reinstall of windows.
    I've seen many machines of that vintage start to have windows update problems that causes all sorts of cascading performance issues.
    --Jon Chuchla--
  3. #33
    Delafield,WI
    249
    I have my effects editor back. I decided to just rename the vixen appdata folder. That fixed the issue. So I dug a little deeper and looked at the settings.xml file.
    This was in the old file:
    <TimedSequenceEditorForm>
    <DockLeftPortion>1753</DockLeftPortion>
    <DockRightPortion>428</DockRightPortion>
    This is in the new file:
    <DockLeftPortion>150</DockLeftPortion>
    <DockRightPortion>150</DockRightPortion>
    The pc only has one monitor 1280x1024. Learned something new today!
    Roger
  4. #34
    7,961
    You must not have deleted the file earlier. The file would have been recreated exactly the same way regardless if you just deleted the file or the whole folder.
    By the way. The editor pane was visible even with the settings you sent. Since you have a low res monitor it would have been off the edge of your screen. But that also means your sequence editor window would have been much wider than your visible desktop. That should have been obvious because you wouldn't have seen the standard windows control buttons on either the left or the right upper corner.
    --Jon Chuchla--
