Page 35 of 35 FirstFirst ... 25333435
Results 341 to 347 of 347
Thread: Buffer/line driver - null pixel without pixel
  1. #341
    3,578
    Default Re: Buffer/line driver - null pixel without pixel
    Moisture? Overvoltage? Not enough sunscreen?
  2. #342
    Colorado Springs
    3,692
    Curious you should mention failures, I had 2 this season also, and they had only been used 1 season.
  3. #343
    311
    Did you do a post-mortem to determine cause of death?
  4. #344
    Aug 2010
    Wilmington, NC
    1,534
    I would suspect a solder blob or a stray wire at the pads. These boards aren't crazy complicated. I get my magnifying glasses on when soldering though because the pads are so close together because of its size and it's EASY to bridge a pad!
  5. #345
    Colorado Springs
    3,692
    When I solder mine up, I place the Data line on the bottom of the board. Makes it a lot easier to avoid solder bridges. I then cover them with 1/2" adhesive lined shrink tube. Can't figure out why they would fail..........
  6. #346
    Kansas City Missouri
    2,000
    I'll have to take off the adhesive lined heat shrink and see if anything is wrong.
  7. #347
    Nov 2012
    Cary, NC, US
    1,202
    I am getting shipment of them tomorrow. Here's more information.
