Page 2 of 35 FirstFirst 123412 ... LastLast
Results 11 to 20 of 347
Thread: Buffer/line driver - null pixel without pixel
    Nov 2012
    Cary, NC, US
    1,200
    Default Re: Buffer/line driver - null pixel without pixel
    Why would you need direction control? Pixel data is unidirectional.
    5,324
    Of course. But it would allow you to build all the boards the same way (with just a jumper), rather than two different assemblies, one each for transmission and reception.
    3,464
    I'm assuming that the board is assembled two ways, one with a transmitter chip and one with a receiver? A five-pin chip doesn't have enough pins to have a direction-control pin.
    Why would there be a need for a receiver? This looks like a straight driver chip used in a regeneration mode. same level in and out the only timing change would be a transition latency which would be common to both clock and data.
    5,324
    I was assuming a differential line driver and receiver.
    Nov 2012
    Cary, NC, US
    1,200
    No, this is logic level driver.
    However, I do have differential data board that I have created for my floods and that one does have in and out (it actually has 2 pars of inputs and outputs, one diff, one logic level.)
    Do you think there's need for differential driver set?
    3,464
    Differential Pixel extender already exists. This is simpler (and cheaper)
  7. Thanks RobG thanked for this post
  8. #17
    Tucson, AZ
    668
    What would be the time frame for these from group buy to shipping?
  9. #18
    Nov 2012
    Cary, NC, US
    1,200
    Well, if I skip test boards, I could ship in 2 weeks, 3 at most.
  10. Thanks tucsonlights thanked for this post
  11. #19
    Oct 2013
    Medicine Hat Alberta
    251
    I would be in on this as well, what do you need to get it rolling? I would take 2 dozen maybe more, does it work with 5v and 12 v ?
    Help is just a mouse click away
  12. #20
    Mar 2015
    Portland Oregon USA
    366
    In simple terms, it can be all one unit. In digital communications it is called a repeater. Input, clean and send.
