Page 29 of 29 FirstFirst ... 19272829
Results 281 to 288 of 288
Thread: Buffer/line driver - null pixel without pixel
  1. #281
    9
    Default Re: Buffer/line driver - null pixel without pixel
    Rob, Can you provide instructions on how to solder the bridge for 5v use please.
  2. #282
    Tampa, FL
    1,261
    Received mine today Thanks
    Sent from my SM-G935V using Tapatalk
    Chris
    Holiday Lighting, LLC
    Your Source for Genuine Mean Well Power Supplies
    https://holiday.lighting
    https://facebook.com/holidaylightingllc
    @holidaylightin9
  3. #283
    Nov 2012
    Cary, NC, US
    1,066
    Quote Originally Posted by ComPeter View Post
    https://www.diychristmas.org/wiki/in...ile:Bld-lv.png
    “If somebody offers you an amazing opportunity but you are not sure you can do it, say yes – then learn how to do it later!” ― Richard Branson
    My [URL="https://www.tindie.com/stores/RobG/"]Tindie[/URL] store
  4. #284
    9
    Thanks for the image Rob. I'm guessing, but to change to LV we just drop some solder in the hole to bridge it or is this where to attach the 5VDC positive lead?
  5. #285
    Nov 2012
    Cary, NC, US
    1,066
    You have to "switch" solder bridge to bypass 5V regulator. Remove solder ball from the bridge and add new one on the LV side
  6. #286
    9
    Thanks Rob. It doesn't paint a clear picture on what needs to be done so I'll wait until they arrive and then ask questions from there. Appreciate your time.
  7. #287
    Nov 2012
    Cary, NC, US
    1,066
    To switch from 12V-24V to 5V:
    1. remove existing solder bridge
    2. all 3 pads should be separate now
    3. solder bridge on the LV side
    BTW, you can use boards with default setting of 12V-24V in 5V environment, but you will not get the full 5V on the data output (it will work, just not as good.)
  8. #288
    9
    Thanks Rob. 100% exactly what I needed to understand what I need to do the switch over. Many thanks.
