Page 1 of 35 12311 ... LastLast
Results 1 to 10 of 347
Thread: Buffer/line driver - null pixel without pixel
    Nov 2012
    Cary, NC, US
    1,187
    Default Buffer/line driver - null pixel without pixel
    The most common way to combat effects of cable capacitance (and other issues) and improve signal quality is to use null pixel.
    That means you have to make sure you add all those null pixels to your sequence.
    The better solution I think would be to create a small buffer/line driver board which could be used instead of null pixel. The good thing about it is that it will work with any pixel protocol, will be transparent to the sequence, and will work with any voltage.
    If we do GB, the price of such driver would be ~$1.50 or less.
  2. Likes MrSmoofy, Phil Spencer, angus40 liked this post
  3. #2
    3,370
    Default Re: Buffer/line driver - null pixel without pixel
    I would take some. This is a much better solution than working with null pixels.
  4. Likes tucsonlights liked this post
  5. #3
    Tucson, AZ
    668
    Quote Originally Posted by RobG View Post
    I'd be in for 10. How does it work?
  6. #4
    Nov 2012
    Cary, NC, US
    1,187
    Nice to see such a quick response
    Now, the question is, should we make it SMT like on the image or through hole (TH would be 2x or 3x larger.)
    Quote Originally Posted by tucsonlights View Post
    You plug it inline just like null pixel.
  7. #5
    Tucson, AZ
    668
    I like through the hole...what would be the dimensions of both?
  8. #6
    Tampa, FL
    1,338
    I would take some too I've not needed any yet but would buy some just to have on hand.
  9. #7
    Richardson, Texas
    359
    I'd be in for 10
    "There's no such thing as a dumb question, except for the question that was never asked!!"
    Mark
    2014 4 channel Mr. Christmas unit, 3,000 lights.
    2015: 32 channels, over 7000 lights including 4 singing faces! (updated)
    2016
    Who the heck knows, I don't!!
    http://pavukchristmas.com
  10. #8
    Oct 2008
    San Jose, CA
    10,283
    Not sure if you've seen THIS? (uAmp)
    Brian
    Halloween in San Jose! - FB
    2015 Halloween Show - Planning now - hopefully some house projection...
  11. #9
    Nov 2012
    Cary, NC, US
    1,187
    No I haven't, but it's pretty much the same functionality.
    The dimensions will be:
    SMT 0.9" x 0.45"
    TH 1.25" x 0.5"
  12. #10
    5,324
    I'm assuming that the board is assembled two ways, one with a transmitter chip and one with a receiver? A five-pin chip doesn't have enough pins to have a direction-control pin.
