Page 1 of 18 12311 ... LastLast
Results 1 to 10 of 177
Thread: 50W RGB LED driver board (WS2811 version)
    Nov 2012
    Cary, NC, US
    1,072
    Default 50W RGB LED driver board (WS2811 version)
    I am in the process of testing 50W RGB LED driver boards.
    They are the same size as 20W LEDs, but larger flood enclosure is needed due to generated heat.
    The driver works very close to the top limit of some of the parts, so dedicated power supply should be used for each flood (will probably fit in the flood itself.)
    @24V, blue LED runs @50% (red and green is fine.) @27V, blue is pretty much at @100% and this is the voltage I would recommend.
    I will have few boards available for those who are willing to do thorough tests.
    “If somebody offers you an amazing opportunity but you are not sure you can do it, say yes – then learn how to do it later!” ― Richard Branson
    My [URL="https://www.tindie.com/stores/RobG/"]Tindie[/URL] store
  2. Likes MrSmoofy liked this post
  3. #2
    San Jose, CA
    167
    Default Re: 50W RGB LED driver board (WS2811 version)
    It looks like you are using doubled-up 1/4W resistors. Any particular reason?
  4. #3
    Nov 2012
    Cary, NC, US
    1,072
    To get 600mA, you would have to use 0.165ohm resistors, which are very rare. 0.33ohm are common and cheap, and using 2 of them in parallel solves this problem.
  5. #4
    San Jose, CA
    167
    Makes sense
    Sent from my XT1254 using Tapatalk
  6. #5
    houston, TX
    420
    I would like to point out that 28vdc is a common aircraft power rail. It should be easy to find 28vdc power supplies.
  7. #6
    Tampa, FL
    1,263
    Quote Originally Posted by Shockwave View Post
    I looked around and 28vdc seem to be hard to find for under $50 each and the one I saw was 60 watt so you would need 1 per flood light.
  8. #7
    May 2012
    Vancouver, WA
    848
    I'm planning on a 36VDC supply (enough for 6 flood) and one of these to drop the voltage down. The power lines will need to support around 6A of current for 6 floods.
    About $40 bucks for the supply (plus case), and $2.25 for the Buck convertors in the Floods.
  9. #8
    Tampa, FL
    1,263
    Quote Originally Posted by Roterhead View Post
    That seems like a better option.
  10. #9
    Nov 2012
    Cary, NC, US
    1,072
    Quote Originally Posted by MrSmoofy View Post
    You can get 24V/2A supply and adjust it's voltage.
  11. #10
    houston, TX
    420
    The 36v supply would blow up all the pt4115 - they are 30v maximum.
