Page 22 of 22 FirstFirst ... 12202122
Results 211 to 217 of 217
Thread: Can the CG-1500 Enclosure Be Improved?
  1. #211
    Sep 2009
    904
    Default Re: Can the CG-1500 Enclosure Be Improved?
    I'd like to thank everyone for their feedback and we are going to go to 3D print with the design and get this project going!
    David
    HolidayCoro.com
  2. #212
    4
    Quote Originally Posted by dmoore View Post
    We carry mounting boards for all the "common" controllers in the DIY community and nothing against Ron's stuff, but that isn't in our list.
    A mounting grid would be great! The vent is a problem because you can't stack boxes for storage
  3. #213
    508
    If the vent was offset to one side then you could stack them w/ a pair facing front to front
    Matt 2016, 1st Show
  4. #214
    327
    The nice thing about a big plastic box is that you can cut a hole anywhere you need it. Someone suggested a chimney vent for the box and that would work and maintain the stackability.
  5. #215
    Sep 2009
    904
    We will be publishing data on heat accumulation inside this enclosure based on 1-4 PSU's at various loads and run times.
  6. #216
    Dec 2015
    56
    When do you think these will be available?
  7. #217
    Sep 2009
    904
    We just completed the final 3D high resolution print and the mold maker is performing some last minute calculations and so it looks like we are a go for the production of the mold this month with mold completion in April. Some pre-production samples in May and production run (if no problems in May/Early June). Into a container for arrival in July I would estimate at this time. I don't expect any longer than August as this would push back our new controller release which is dependant on this new larger enclosure.
  8. Likes pixelpuppy liked this post
