Page 10 of 17 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 168
Thread: 20W Flood RGB LED driver board (WS2811)
  1. #91
    Nov 2012
    Cary, NC, US
    1,146
    Default Re: 20W Flood RGB LED driver board (WS2811)
    Send me PM.
  2. #92
    Nov 2014
    261
    Rob, you inbox is full and won't accept more messages
  3. #93
    Nov 2012
    Cary, NC, US
    1,146
    OK, try now
  4. #94
    May 2011
    SIKESTON, MO
    1,284
    Rob, Will these be back in available in the store soon. Looking to pick some up. Thanks.
    LANCE
    Find me on Facebook atCHRISTMAS ON PLANTATION
    2017 might look promising for a show
  5. #95
    Nov 2012
    Cary, NC, US
    1,146
    Yes, I am working on it, should take ~4 weeks.
    If you need it now, I can probably find few of them.
  6. Thanks FIRECOP252 thanked for this post
  7. #96
    140
    I've finally finished building my first one of these. Red works fine, but green is very dim, and I get no blue at all. Doesn't matter if I drive it with a controller or with the test pads on the board.
    Anything obvious that I'm missing?
  8. #97
    Nov 2012
    Cary, NC, US
    1,146
    Can you email pictures of your board to me for visual inspection?
  9. #98
    140
    Quote Originally Posted by RobG View Post
    Can you supply me with your e-mail address?
  10. #99
    140
    I've not built a second one of these, and was very careful with soldering. This one has the exact same problem as the first. Using the test points, red seems fine, green is very dim, and no blue at all. Since both boards behave identically, there must be something I am consistently doing wrong. I've tried controlling with x-lights, and I get the same results - red fine, green very dim, no blue. I am running these at 12V.
  11. #100
    Nov 2012
    Cary, NC, US
    1,146
    Hi, the answer to your problem is in your last post. 20W boards require 24V supply (20V-24V) Only 10W boards can run on 12V.
