Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 58
Thread: DM-10x DMX decoders with custom firmware
  1. #31
    Nov 2012
    Cary, NC, US
    1,208
    Default Re: DM-10x DMX decoders with custom firmware
    Yes, exactly, left transcevier can be used for half-duplex. Cascading is done is software.
  2. #32
    Aug 2012
    NA
    10
    Maybe this is why i can't get cascading to work on dm-101's- i was guessing that the two sets of DMX solder points on 103's were just two ways to connect to the same thing, but from that it looks like two chips for two separate dmx paths. I looked at my different controllers- the dm-101 has only one MAX485 chip, the 103,
    2 chips. I was going to be using mostly dm-100DC since most of my emitters are only rgb- those ones have two max485, hopefully they will work with cascading if that's what makes the difference. Thanks for the schematic, once i can get my mind around it, it might help explain some things.
  3. #33
    May 2017
    4
    Hello RobG,
    first thanks for your work in this module.
    actually i have exactly the same problem like Hangman,
    i have an YX-103 programmed with your firmware, 2 channels work perfecly but the red (pin 20, timer2 ch2) dosn't work at all.
    i've tried to swap the STM8S003F3P6 by another one. but same result. all other functions (programmation in data memory for dmx address and receive dmx reception ) work.
    if you have any idea?
  4. #34
    Nov 2012
    Cary, NC, US
    1,208
    Can you post good quality pics of your YX-103 (front and back?)
    Timer on STM8S003F3 has 4 channels, so I am wondering if they switched R to the unused one.
  5. #35
    May 2017
    4
    hi, there is the pictures of the board .
    For information, i've viewed directly on the STM8S003F3 all pin who have an attached timer with oscilloscope, only the pin 13 and 14 have a pwm signal in output.
  6. #36
    Nov 2012
    Cary, NC, US
    1,208
    OK, I think I know what's going on, I uploaded code for a different board (my original DMX board,) red is most likely on pin 17.
    I will fire up STVD when I find some spare time and make a new binary.
  7. #37
    May 2017
    4
    Ok thank you for your time. . I tried to develop by myself for a Chinese 36w spot that is very slowly in dmx mode ... (more than 1 second of response time ..., not usable at all,or only in decoration ...).
    But I don't have enough skill on this mcu ... ^^ your firmware will save them. Keep me informed
  8. #38
    Nov 2012
    Cary, NC, US
    1,208
    Should have something by the end of week, I have to refresh my memory since I only use STM8S for my DMX decoder.
    Once a while, when I want to torture myself with an awful IDE (STVD) and rather poorly documented MCU, I work on STM8S projects
  9. #39
    Nov 2012
    Cary, NC, US
    1,208
    @dazer, can you try this one? I didn't do thorough testing, but R should be working now and I switched G & B. I also removed rainbow effect, will add it back later if needed.
    Attached Files Attached Files
  10. #40
    May 2017
    4
    hello! it's all good! R G B are on the good outputs, and the "R" channel work too.
  11. Thanks RobG thanked for this post
    Likes RobG liked this post
