Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Thread: DM-10x DMX decoders with custom firmware
  1. #41
    Oct 2016
    3
    Default Re: DM-10x DMX decoders with custom firmware
    Nice, it works for me too. Thank you for the fix!
    (And as a hint, I realize it to late but if "red" isn't working you should'nt leave it running and think "hey, at least red is always on" .... the pin isn't either on or off, its floating an after some time the mosfet will burn away )
  2. #42
    Aug 2012
    NA
    10
    When i read through this before i thought the term dm-10x was referring generically to the dm-xxx series of controllers, as in dm-101, dm100dc, dm-103 etc, but after just reading again i guess there is a separate model dm-10x? Where can i find more details about it?
    Also same with YX-103, is that another type of led controller or from the same DM- series?
    What are the differences between yx-103 and dm-10x and the dm-103 (for example). Is there some place that explains each controller in the series in detail? I've only been able to find translated pages, and most of those are copied from other models' spec sheets so isn't even right.
    Most of the Dm series controllers have the 4 solder pads for the usb header, will this mod work on those as well (or 101, or 103, 104, 107 etc)?
    Where do you buy the yx-103 or dm-10x? I couldn't find them on the usual places like alibaba or aliexpress
    These are Q's i've tried for years to find answers to from the mfg, from sellers, or anyone who will respond- it's been pretty rare to find anyone (even the mfg!) who knows anything about them. Surprising and a shame, i'd be buying dozens on a regular basis if i can make it work for our project.
    Does anyone know what Pin and Pout (it's only on some of the dm models) is used for?
    Thanks for any info- it's been impossible to find detailed info for any of these controllers, i've emailed sellers for example who i guess don't know anything about it, they're just drop-shipping. These controllers really make some things possible that you couldn't easily do otherwise. i wish there was more info about them.
    So many other questions about these controllers, sorry for such a long post. Sometimes i see a model listed in two different places (the dm-104 for example) they look like two completely different controllers to the pictures, and none of the sellers knows anything about them. This is one of the few places i've seen a few people who seem be familiar..
    Thanks!
  3. #43
    Oct 2013
    2
    Good day to all!
    Answer my dear RobG !
    I also want to join the issue from robisais,
    Best regards!
  4. #44
    Nov 2012
    Cary, NC, US
    1,200
    Not sure what are you referring to (Pin & Pout,) can you attach picture?
  5. #45
    Oct 2013
    2
    Hello Rob! I'm now in the business team, in 2 days I will post photos and pinouts.
    You are the best! Thank you for responding.
    Sincerely.
  6. #46
    Mar 2019
    Bremen, Germany
    1
    Hello
    Does anyone know how to cascade the DM-101?
    It's supposed to be done over the Pin and Pout, but it does not work with simple wiring.
    All modules have the addresses 1 to 4. Unfortunately, the DM-101 has no DMX output.
    Best regards
    Reinhard
  7. #47
    1,017
    If you've set separate addresses, can't you just connect D+ D- Ground and VCC from one to the next? DMX doesn't "eat" data and the signal is usually good for thousands of feet so it shouldn't be a problem to daisy chain them together.
    I see some of the DM-10x designs appear to have D+ and D- on the output side. That would make sense to me but then the VCC and GND connections were missing so you are still running power separately.
    What is PIN and POUT suppose to do?
  8. #48
    Mar 2016
    5
    Hi, any news on the DM-101 PIN and POUT Ports? I can't get em to work on cascade and its driving me crazy hehehe. Also can someone please tell me which ray were you guys talking about? Was that ray wo or ray from Rita LEDs? Thanks
  9. #49
    1,017
    ray wu in aliexpress and ray at rita lights are the same person.
  10. #50
    Nov 2018
    2
    Did anyone test the custom software with a DM-100AC module? I'm not sure if they use the same pinout for the RGB channels.
