Results 1 to 7 of 7
Thread: Germanium vs Silicon Transistor interchange
    Colorado Springs
    3,713
    Default Germanium vs Silicon Transistor interchange
    I need some info from one of our experts. Can an old germanium transistor (circa 1967), such as may have been used in an auto ignition circuit, be replaced with a modern day Silicon transistor with similar specs? Thanks in advance for your input.
    Morrisburg, On, Canada
    2,540
    Default Re: Germanium vs Silicon Transistor interchange
    Yes, but ...
    The bias requirements will be different and need to be modified. Silicon transistors require around .7 V between base and emitter to turn it on while germanium require around half of that - if I remember correctly.
    If your old circuit used a pair of germaniums then I would recommend a pair of silicon transistors, or even mosfets - depending on the difficulty of the circuit modifications.
    Is that what you are doing, modifying an old ignition system?
    Oct 2009
    Nelson (New Zealand)
    435
    Another cautionary thought, be aware of the type of transistor, often the "Old" Germanium transistors were "PNP" types wheras "most", although not all, of the modern ones are of the "NPN" configuration.
    [B]"Tory Street Lights", Nelson, NZ[/B]
    [B]2013 - "Honourable Mention"[/B] - 2013 Local Christmas Lighting Competition
    [B]2013 :-[/B] 11 x Ren 64XC's - 650 Channels, 45,000+ lights. 7,000 or so LED's this year:-)
    [B]"Lucky Home" [/B]- 2012 Local Christmas Lighting Competition
    [B]2012 :-[/B] 11 x Ren 64XC's - 550 Channels, 40,000+ lights. 2,500 or so LED's for the first time :-)
    [B]2011:-[/B] 7 x Ren 64XC's - 384 Channels, 30,000+ lights - all incandescents! 2 x Commercial LED Panels (72x7)!
    [B]"Supreme Winner for 2010" [/B]Local Christmas Lighting Competition, 4 x Ren 64's - 256 Channels Controlled by Vixen - "Brilliant" :-)
    18,000 to 20,000 Lights - all incandescents! 2 x LedTricks Panels with "Pix C" interface's
    [B]2009:- [/B]128 Channels of "Hill 320", 4,000 Lights
    Colorado Springs
    3,713
    Yes, but ...
    One of the members of a classic car forum I belong to is working on one, and the question came up.
    2,540
    Ahhh.... yes CD ignition systems.
    I had a homebuilt Cd ignition using the original ignition coil - back in the 70's. I had also added 2 toggle switches to revert to the original configuration. After leaving home and halfway to work on the busy highway my CD ignition died. Flicked the 2 toggle switches and I was good to continue to work. I stopped playing with the idea then when I couldn't keep the reliability up. I was using a regular small power transformers (120VAC - 12VAC) instead of a proper switching transformer.
    I still have the Radio Electronic magazine articles on CD ignitions and can look there to see what was used - if needed.
    houston, TX
    450
    Silicon transistor need .65v bias between base and emitter. Germanium is .35v. If it is only shorting to ground then yes, it should work. If it's part of an amp then the design of the amp will need mods.
    And wow - I cannot remember the last time I saw a Ge transistor!
    Colorado Springs
    3,713
    Yes, part of a CD ignition system. Thanks for the info gang!
