Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Cheap DIY 12mm Pixel/RGB Mounting Strips
    Oct 2013
    76
    Default Cheap DIY 12mm Pixel/RGB Mounting Strips
    I just wanted to share something I discovered that works really well as a DIY alternative for 12MM Pixel Mounting strips. You can buy 3/4 inch wide Polypropylene Hanger Straps in 100 foot rolls that come with pre-drilled 1/8" holes spaced 3/4 inch apart.
    They cost $7.90 each from Amazon plus shipping. The shipping for one 100' roll would be $3.80. The shipping on ten 100'rolls, (or 1000 feet) would be $11.90. So, in essence, if you are building a 20 foot 50 string Megatree, you could get a whopping 1000' for $90.90. You can find them on Amazon here
    You can then drill out the holes to 12mm to fit the 12mm pixels. Forstner bits or something similar works really well for drilling the holes. Since they have pre-drilled 1/8" holes at 3/4 centers, it makes drilling them a breeze. Perfect spacing with no measuring. You can drill each hole for 3/4 inch centers or every other one for 1-1/2 inch centers.
    I found that this bit from Amazon works very well.
    using the 12MM bit above, the pixels are held very snug and don't even really need to be tie wrapped. The straps before drilling are rated to hold a very very conservative 20 pounds. Even after drilling they are stronger than that. So, they can be drawn quite tight.
    You can find other similar products in black and possibly other colors.
  2. Thanks RobG thanked for this post
    Likes angus40, RobG liked this post
  3. #2
    Dec 2009
    WesternTreasure Valley, Idaho
    1,206
    Default Re: Cheap DIY 12mm Pixel/RGB Mounting Strips
    You could get the same amount here and save time and money. Usually shipped in a flat rate box.
    http://boscoyostudio.com/products/in...l93m0go6ti5k30
  4. Thanks RobG, BizeekDIY thanked for this post
    Likes RobG, BizeekDIY liked this post
  5. #3
    Oct 2013
    76
    Quote Originally Posted by THurrle View Post
    Yes, and those are actually better. I am not knocking them, but for someone on a budget who does not mind just a little more effort, these can be had for less than half the money. ...just a DIY alternative and they are readily available at your local big box store. This is just something I stumbled across. I had a couple of rolls of this strapping left over from a remodel. It is actually used for pipe hangers.
  6. Likes TazChaLet liked this post
  7. #4
    Oct 2013
    76
    BTW... with a DIY solution, you also have a little more flexibility. With these, you can space your pixels at any multiple of 3/4 inch. So, you could do 3/4 inch spacing, 1-1/2 inch spacing, 2-1/4 spacing, 3 inch spacing ... etc.
  8. #5
    Nov 2015
    North Yorkshire, England, UK
    47
    AND for us DIY guys in the UK we can get this on Amazon UK too...
    Great find. Thanks
  9. #6
    Jan 2014
    Palm Bay, Florida
    1,431
  10. #7
    Colorado Springs
    3,661
    And I happen to have a 99' roll of that stuff right here on my desk. $5.99 plus shipping & pp. Send me a PM if interested.
  11. #8
    Southern IL
    943
    Quote Originally Posted by stallionent View Post
    Shows $8.97 at my home depot
  12. #9
    Jan 2014
    Palm Bay, Florida
    1,431
    My error, I bought it at Amazon $11.74 free shipping with prime. I also bought a 12mm drill. Both work great.
    Drill (picture is wrong): http://www.amazon.com/gp/product/B00...ilpage_o00_s00
    Strap: http://www.amazon.com/gp/product/B00...ilpage_o01_s00
  13. #10
    Nov 2015
    Uk
    39
    Quote Originally Posted by dcall View Post
    Great find. Thanks
    Do you have a link what i found on uk amazon was expensive. Thanks
  14. Likes Mat-Moo liked this post
