No possibility of this KC?
In the Event Sequence Audio window can we change the "OK" button to "Done"?
The reason is there are instances when someone assigns buttons to different channels to use them as a tapper you may click "OK" and then the window closes and you have to start over again. "Done" would indicate this action and people would be less likely to click the "Done" button until they are done with the window.
