Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 5v SianSmart SSR to control 12v Dumb LED's
    5,343
    Default Re: 5v SianSmart SSR to control 12v Dumb LED's
    Thoughts? That document is a bit skimpy on details, and I didn't get around to finding the full specs on the web.
    Morrisburg, On, Canada
    2,540
    Quote Originally Posted by CatMan42 View Post
    Howdy LightUp,
    I've been looking at DC SSR's, and think that this one may work with Z's sketch and the SainSmart boards. I know they won't plug straight into the board and I'll have to make a sub-board and patch it in, but just wanted to get your opion before I order 25 of these (only need 16, but like to have spares on hand).
    Your thoughts?
    Mark
    Basically it should work as a DC SSR.
    But ... slapping this DC SSR into an existing sainsmart board may not be as simple. One could buy 1 or 2 SSRs and experiment on the bench, but the datasheet for actual SSR used and the schematic for the actual sainsmart board would be most helpful. Otherwise you are 2nd guessing, (which you are asking me to do,) - which to me is poor engineering.
    Edit: I did find a pdf datasheet for the AQZ10 but it didn't exactly match your photo.
    http://datasheet.octopart.com/AQZ202...eet-610584.pdf
    OK, I did find a "voltage version" datasheet.
    https://www.panasonic-electric-works...df?type=target
