Results 1 to 10 of 12
Thread: 5v SianSmart SSR to control 12v Dumb LED's
    Richardson, Texas
    359
    Default 5v SianSmart SSR to control 12v Dumb LED's
    Hope this hasn't already been answered, but I've read all the threads and didn't find the answer. Is anyone using the SainSmart 8 channel SSR board to control 12v dumb (2 wire) LED strips? I built zparticle's 32 channel controller, but need 16 channels of 12v LED. I've swapped the zero cross relays for random cross for dimming control, but the 12v LED lights stay on even after putting a snubber in.
    Or, am I approaching this wrong? Is there a controller that will already do this. Keep in mind, I need 16 channels of 110v and 16 of 12v.
    Thanks in advance for all of your help!!
    5,343
    Default Re: 5v SianSmart SSR to control 12v Dumb LED's
    You can't use AC SSRs to control DC lights, as they won't turn off until you remove power. Since you mention zero-crossing SSRs (which are used to control AC) that these are what you are trying to use to control the DC strips. They won't work there, you need to find DC SSRs.
    Morrisburg, On, Canada
    2,540
    Also, trying to use the same sketch for both AC and DC SSRs is problematic. You're better off using one sketch for AC SSRs and use another Arduino and sketch for DC SSRs - unless you can integrate both within the sketch, but that requires more homework ..
    2,540
    On 2nd thought the Arduino channel port outputs for the SSR board is a PWM signal. So you should be able to mix AC SSRs and DC SSRs as long as each type of SSR can handle the Arduino PWM output signals. As mentioned before the AC SSR requires a ZCD circuit while the DC SSR does not.
    Richardson, Texas
    359
    Morning LightUp, you wouldn't by chance know what the output voltage of the PWM is on the MEGA would you? Looking at a couple of different options for the DC relays.
    Richardson, Texas
    359
    Quote Originally Posted by CatMan42 View Post
    Nevermind, I found it.
    PWM signals are rectangular waves, varying from zero to +5 V, with a frequency near 500 Hz. If the signal is high for 50% of the time, the voltage delivered will be 2.5 V.
    2,540
    The PWM signal I was thinking of was the 120 HZ in sync with the 60HZ AC line, as created by the zparticle 32 channel AC dimming sketch.The Arduino port output would still be 5V swing for SSR input.
    Thismeans that the same sketch could handle both AC and DC SSRs at a PWM frequency of 120 HZ.
    Richardson, Texas
    359
    So if I understand you correctly, technically all I would need to do is switch out the random cross (A/C) relays for DC to DC relays. Right?
    Richardson, Texas
    359
    Howdy LightUp,
    I've been looking at DC SSR's, and think that this one may work with Z's sketch and the SainSmart boards. I know they won't plug straight into the board and I'll have to make a sub-board and patch it in, but just wanted to get your opion before I order 25 of these (only need 16, but like to have spares on hand).
    Your thoughts?
    Mark
    Richardson, Texas
    359
    Deleted duplicate post
