Results 1 to 10 of 21
Thread: E1.31 and Artnet Reception Sketch for Pixel Control
    Jul 2013
    116
    Default E1.31 and Artnet Reception Sketch for Pixel Control
    I wanted to share my finalized sketch for controlling pixels via E1.31 or Artnet. This sketch uses the FastLED library to drive the pixels and also includes Matterdaddy's Glow with the Show library for controlling GWTS ears. It can receive multiple E1.31 universes and includes a power on self test function as well as a standby function for when no data is being received.
    The sketch can be found here
  2. Thanks gunther thanked for this post
  3. #2
    2,192
    Default Re: E1.31 and Artnet Reception Sketch for Pixel Control
    Jared:
    Nice work.
    You apparently developed this on an M2560; have you tried it on an UNO?
    Also: have you tried it under IDE 1.6.0?
    Congrats.
    \dmc
    ________________________
  4. #3
    Jul 2013
    116
    Quote Originally Posted by dmcole View Post
    Jared:
    Nice work.
    Congrats.
    \dmc
    I did develop this on the Mega 2560 R3 but I did test it on the Uno and it does work. The Uno won't be able to handle as many pixels as the Mega since there is less RAM. I developed this on IDE 1.0.6 but I just upgraded to 1.6.0 and it does still work except for the GWTS library. It compiles with no errors but I'm not getting any output to the ears. Still working on that.
  5. #4
    2,192
    Quote Originally Posted by djred2000 View Post
    Do you have a handle on how many pixels an UNO will handle? Or a Mega?
    Also, there will be much midnight oil being burned over the next few weeks as developers tweak their code to work with 1.6.0.
    \dmc
  6. #5
    Jul 2013
    116
    \dmc
    I don't know exactly, but there are other threads that have talked about it. The Uno should handle at least one full universe which is about 170 pixels. The Mega should be able to handle 2-3 universes, possibly more. I only have three 50-pixel WS2811 strings and the Uno can drive all three together with no problems.
  7. #6
    Jul 2014
    Missouri
    134
    This worked great on the Mega. I finally got an ether shield in and set up last night. I ran 300 WS2811 pixels with Vixen 3.
  8. #7
    Jul 2013
    116
    Quote Originally Posted by jwamsley07 View Post
    Great! I'm glad it's working for you.
  9. #8
    Jul 2013
    116
    I wrote another sketch for controlling relays using E1.31 or ArtNet via ethernet or WiFi. I am using a Mega 2560 R3 with the Sainsmart 8-channel relay board (not solid state). The sketch can be found here
  10. Thanks jwamsley07 thanked for this post
  11. #9
    Jul 2014
    Missouri
    134
    Can this be modified to work with 16 relays or is there a limit of 8?
  12. #10
    Jul 2013
    116
    Yes, it will. Just modify the NUM_RELAYS define and the relay pins array.
