Results 1 to 10 of 11
Thread: Looking At this for next year
    Oct 2009
    Bennington, NH
    248
    Default Looking At this for next year
    not to sure where to post this but i have some questions about using this. how do i get the sequences i do in vixen 3 into the format needed to run on the Pi. I'm missing something, is there a video or a tutorial on how this is done???
    any help will be greatly appreciated
    Joe O'Brien
    Trying my first Pixel Tree this year!!! i had good luck last year with some Pixels and Falcon Player / Pi
    Facebook: [url]https://www.facebook.com/obrienfamilychristmas[/url]
    7,961
    Default Re: Looking At this for next year
    Open the sequence in the editor, and then use Export in the sequence menu
    Nov 2012
    Toronto, ON.
    250
    Sparky,
    Not to promote another forum on this site as I know many of the same users float between multiple blink-flashy related sites but I found very helpful info over at the Falcon Christmas forums in the Falcon Player section (FPP). That is where I started - well, after this site of course!
    Shane
    Nov 2013
    Morganton,North Carolina
    1,690
    Good decision on the FPP,I ran it for the first time this year and it is Fabolous.
    As mentioned just export it as a FPP file.
    (1)Falcon F16V3
    (1)Renard SS16
    (1)Renard SS24
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Become A Supporting Member
    Falcon Christmas
    Renard Controllers
    Eagan, Mn.
    4,073
    Import your Vixen 3 sequence into Xlights and use the convert tab.
  6. Likes rfallatt liked this post
  7. #6
    7,961
    Last I checked xLights can't import Vixen3 sequences. They may have changed this recently. But to my knowledge, you must use the Vixen 3 export function to convert a Vixen 3 sequence to any other format.
  8. #7
    Eagan, Mn.
    4,073
    I believe that there is a version of Xlights that is compatible. I don't remember what the version number is. Maybe a search or email to Sean would put you on track.
  9. #8
    Oct 2009
    Bennington, NH
    248
    Another question. Right now one one of my universes has 2 ren32's and a ren24dc. The 2nd ren32 only uses 1 thru 5 the last 12 channels are empty and the rendc is being completely used. I of course have this mapped on vixen 3. Dose the output mapping transfer to falcon when i export the sequence or am i not allowed to skip channels
    Joe O'Brien
  10. #9
    Oct 2012
    Pleasant Prairie, WI
    1,110
    if it is mapped in Vix on the export, it will transfer into FPP as it is in Vix.
    2012: 24 channels with 1 Renardss24 * 2013: 48 channels with 2 Renardss24's * 2014: Took the year off * 2015: Life Got in the Way
    2016: 1000 Channels for Halloween, mix of A/C, RGB, Pixels. Christmas over 17 universes, all Pixels, oh boy...
  11. #10
    7,961
    When you're exporting you have the ability to reorder your controllers in the export screen. Just drag them to the order you need.
    This will be further improved later this year. We're working with the FPP team on some integration features that will not only export the sequences from vixen but also create the fpp config files and push it all directly to the fpp.
    --Jon Chuchla--
