Results 1 to 7 of 7
Thread: bug in execution of custom effect
    31
    Default bug in execution of custom effect
    Hello,
    Im trying to get a custom effect to randomly appear only once.
    I tick random with 35% coverage
    And I tick "single effect only"
    My selection box is 84 X 20 and the effect is only "2" long
    The effect gets drawn only once but they all start at the beginning of the selection window, so there is no random coverage anymore.
    Am I doing something wrong or did I stumble upon a bug?
    Greetings, Robert
    6,215
    Default Re: bug in execution of custom effect
    I just tested this and it works perfectly
    click on effects / add custom effect group and define >
    click Add an effect to add a row
    type > user select
    length > 2
    strat value> user define
    end value > user define
    name> user define
    click ok and exit
    open display group draw selection box >
    click custom
    execution of custom dialog pops up
    select random top right
    adjust coverage > user define %
    select random intensity > if using ramp < otherwise uncheck all boxes on left hand side
    if you want rgb color other than pre defined > click use rgb effect color and ignore cuctom color button
    if not a segment channel > select > segment channel treat as individual channels
    > your good to go <
    6,215
    Here is a quick demo .
    hope it helps .
    31
    Hello angus40,
    Thanks for the info. What you show me works great, but...
    The effects appear more than once in every channel.
    It is my understanding that if I check "single effect only" that every effect
    appears only 1 time in every channel...
    Greetings, robert
    31
    Just made to screen shots to let you see what I get.
    In hls1.jpg you see what I have selected.
    in hls2.jpg you see that all the effects get drawn at the first position...
    I don't know if this is what it should do.
    I thought that the effect gets drawn only once in every channel but at random
    Greetings, Robert
    6,215
    do not select single event , this will load a single tic event .
    leave all unchecked if using a level effect .
    changed the coverage to 2 % and you will get Pic # 3
    cheers
    6,215
    here is visual
