Results 11 to 20 of 34
Thread: Help Repairing My Sagging Inflatables - Is Rejuvination Possible ?
    821
    Default Re: Help Repairing My Sagging Inflatables - Is Rejuvination Possible ?
    Look for a silicone sealer that is used for shoes or fabric. I don't remember what the name of the kind I used is right now as I am not at home. I will try to remember to check when I get back home and post here for you.
    Something like this:
    http://www.amazon.com/Atsko-Sno-Seal...BHX8WC08R6V30A
    8,001
    I also seal them with a silicone based deck sealer. I get it by the gallon in the paint section of the ace hardware. I just put it in a pump sprayer and spray it on. I usually use the spray bottle style because you don't need a lot. I do it when it's not inflated, because if there is leaks, it's just going to keep bubbling at the leak and not actually seal it. It also works great for waterproofing tents. It's a bit pricey though. I seem to remember it's around $45/gal.
    I used to use Thompson's Water Seal, it's much cheaper and easier to apply because it's thinner, but you can't get it around here any more due to the stupid "protect us from ourselves" anti VOC laws. They still sell something with the same name in similar packaging, but now it's water based, has zero smell, and doesn't work for anything.
    821
    I just woke up and thought about another possibility for you in sealing that you can try as well.
    You can get a product called Seam Seal from most places that sell camping gear or outdoor stuff. I used to use it on my tents back when I was much more of an outdoors man than now .
    Take the inflatable and lay it out and run some seam seal onto the sewed edges and let dry. This will probably take awhile to do as you need to let the stuff dry before you go moving the item around. It helps if you can hang the item onto a clothesline or some way that lets you do the most seams at a time.
    This makes the seams air and water tight but doesn't affect the fabric so much. Of course this method boils down to how much time and effort you want to put into saving an inflatable and what it is worth to you. I have a couple that I only put out every other or every third season and they are really pretty nice so I am careful with them and want to make them last awhile.
    Also now with the throw away mentality of out society, I think that some of the really "cool" inflatables will be extinct very soon and you won't be able to buy them anymore before too long so why not take a few minutes to help them last a few more years?
    25
    I have a number of large inflatables, and over time they develop leaks like the ones you're describing. I think the problem with the seams is the thread is not UV resistant and just breaks down over time. If it's black, I have used Gorilla Tape while it was inflated with quite a bit of success, but if it isn't I actually hand-sew whatever is leaking, and that has worked quite well, too. I have a 12 foot hearse that is no longer made, that has Dracula in a coffin inside that pops up and down. Over time, I had developed a lot of pinhole leaks, and this year I went out with matching thread and just sewed them up.
  5. Likes beeiilll liked this post
  6. #15
    Parowan, Utah
    682
    mmmmm wonder if this will work on my sagging chin ??????? Sorry the devil made me post this
    " Hot glue is your friend "
  7. #16
    Jan 2013
    Pennsylvania
    46
    I tried using the 50-50 mix of fabric softner (I used downey) and water. It worked unbelievably well, I only found that I had to respray after rain.
  8. #17
    Dec 2015
    2
    I use starch
    Sent from my SPH-L720T using Tapatalk
  9. #18
    25
    Traneman--a person after my own heart! I always say that pregnancy is when your shirttail goes from hanging on the inside to hanging on the outside--and it NEVER goes back!
  10. #19
    Nov 2015
    Milwaukee
    2,225
    In my younger years (several decades go), there used to be a tent seam waterproof product that came in a roll-on container. Like the (really)old school deoderant rollons with the big plastic roller balls. Not sure if that would fix it or not.
    Prior to that innovation, we used white hurricane candles. We would snip the wick off and rip it out the bottom of the candle. Then we would draw on the seams with it like a crayon. Dunno if that would help with air but it darn sure helped(helps) with water.
  11. #20
    821
    You can still get tent seam waterproofer in tubes and spray. The newer stuff is nice as you can find it in a silicone based formula that has UV inhibitor in it as well!
    I still just use a good silicone spray and spray it through the fan while the inflatable is up and running. It tends to go to leaks and will plug them if not too big. Although using a candle to help plug bigger leaks sounds like a good trick along with the spray to seal things better.
