Results 11 to 20 of 23
Thread: Powering LED Strings and SSRs
    Southampton, United Kingdom
    102
    Default Re: Powering LED Strings and SSRs
    I have a multimeter - just need to get it out of the box a little more often!!
    3,006
    From the four pictures you presented, 3 are AC output, the fourth is DC.
    (My guess, based on much experience at getting it wrong when I was a much younger man.)
    A very quick tell is to look downstream from the controller. If there is a rectifier inline, you probably have AC out of the power packs.
    (LED lights by their very nature are DC, therefore only use one side of the wave.)
    102
    Having looked again at the pictures I can see what you mean now about the secondary output. 3 of them show the wavey line for AC and I can see the other one shows the solid and dashed line for DC. I'm learning all the time!! I have so many of these power packs and I really want to reduce them to a few power supplies that I can feed directly in to the SSRs, therefore not needing one of these wall warts on every single output from the SSRs.
    Am I correct in thinking that if I match the output of the wall wart with a different power supply that should work okay. For example, if I have 4 LED sets all with their own "DC output" wall wart (as pictured) could I use an SMPS instead which provides 30VDC to a DC SSR which then has a single string of the LED lights from each of the 4 outputs. And as for the LED sets with the "AC output" wall warts could I use a toroidal transformer, which provides 24VAC to an AC SSR and then have a single LED string of each of the 4 output channels. Is this too simplistic or does that all make sense??
    Texas
    326
    I think it would be unwise to plug wall warts directly into an SSR - at least if you were going to be doing any dimming. Rather you would match the output power of the SSR itself with what you need. If you need 24VDC, use a DCSSR and a 24VDC power supply into it (A nice SMPS would be fine here). If you need 24 VAC, use an ACSSR and a 24VAC transformer to it.
    102
    I've looked at some of the lights I have and from what I can see the ones that have a power pack with AC output do have a block in the wire. I've attached a picture to show you what I mean. Is that likely to be the rectifier?
    Sep 2013
    Newhaven, East sussex, uk
    437
    Hi there.
    That's a good question. I bought a lot of led strings last year that rusted up good. They had a multifuntion controller connected to them. Not one had the block as shown though. I need to research more
    80+ plus channels
    2 x 32 channel custom build tlc5940 dimmable DC controllers.
    1 ren 48 LSD v3c
    All rgb strips and 1 custom made face.
    102
    I'm going to guess that your lights had power packs with a DC output. As I said before, I think the block in the wire (as picture) is to do with converting an AC output from the power pack in to a DC supply for the LEDs.
    Can anyone confirm if this is correct??
    4,853
    Quote Originally Posted by m00dawg View Post
    There is no problem using the output of an AC wall wart to power an AC SSR (Lower voltages work while higher voltages than the specified design voltage causes magic smoke). Dimming will require the PWM version of the software. So if you insert the AC SSR between the Wall Wart and the LED string, you should have functioning control, as long as the string was of the constant ON type. If there is a multi-function control box between the wall wart and the string then you will have to bypass the control functions in that box. FYI: I had some of these strings and replaced the multi-function control with a full wave rectifier bridge and it worked very well.
    I would also like to correct a statement made in an earlier post: For the 64XC and any other controller that uses external SSRs, it IS possible to mix and match DC and AC SSRs. I myself run 8 channels of AC and 32 channels of DC on my Ren 64XC. NOTE: Controllers with integrated SSRs cannot mix and match on the same controller.
    102
    In your post you talk about a full wave rectifier bridge. Is that what the things are likely to be in my LED string wiring (post #17)?
    Texas
    326
    Would that depend on the wall-wart? A DC linear regulated wall-wart, for instance, I would think would behave differently over an AC one. No clue what a switchmode wall-wart might do in that case. Someone feel free to school me on the topic
