Results 31 to 38 of 38
Thread: This is why we fuse everything.....
  1. #31
    Sep 2012
    Seattle, WA
    630
    Default Re: This is why we fuse everything.....
    on the +12V output of the power supplies I used this 30A circuit breaker http://www.delcity.net/store/search/...jsp?item=75135
    I just wanted to say, the picture of your controller really impresses me. I'm obsessive about neat wiring, and just love your layout. What connectors are you using to pop out of the box, for both the pixel wires and Ethernet?
    -=Steve
  2. #32
    121
    It looks like you have it wired to the neg side. Shouldn't it be on the pos side.
  3. #33
    Eagan, Mn.
    4,073
    Quote Originally Posted by Don6699 View Post
    So was this the last GB?
    Mybe there should be another one.
    Attachment 31714
    I believe that he still has some. Maybe pm him.
  4. #34
    Sep 2013
    Eastern townships quebec,30 miles east of sherbrooke
    92
    I was just finishing hanging and connecting everything .I had all the lights on and just about to connect the last string . there was a sizzle. a connection burnt at the rectifier(which was properly soldered.the + wire burned off the rectifier).now,nothing works. no lights no nothin. no blackening or smoke smells from the renard box. I tried the outlet and its working .but no lights work. I restarted my vixen program and still just nothing is working . I looked at the 2 fuses in the box and they look fine.
    please help me guys.im freakin out a little here.
  5. #35
    1,218
    Unplug all strings and get the volt meter. Grab your renard instructions and check for proper voltages on the board. Pull the pic if you haven't. Once you verify voltages, flash the pic and see if it takes it. Put it back in and do a all on sequence without lights. Verify voltage at each output.
  6. Thanks MacSHROOM thanked for this post
    Likes MacSHROOM liked this post
  7. #36
    Sep 2013
    92
    thanks Mike.i can start checking the voltages tomorrow when theres more light ..i don't have a pic flasher and I don't even know where id go to find one to borrow or use.i live in the middle of nowhere.so I hope its not that.i cant find a list of voltages and where to check them .would you be able to send me a link to that page please? its been a good few years since I assembled mine.
    thanks very much for your help. I'm feelin a little down right now.i don't believe this just happened.
  8. #37
    1,218
    It looks like you might have a SS24. The wiki has the information but it was easier to find my way there from google.
    http://www.doityourselfchristmas.com...he_Renard_SS24
    If you have a different board, post back and someone will point the way.
  9. #38
    Sep 2013
    92
    thanks very very much. it was dark when it happened and I was in a bit of a state. I was using a crummy old flashlight to see in the box. as it happens,i think it is just a matter of replacing a 10A fuse.
