Results 1 to 8 of 8
Thread: SSR board Cat5 cable distance?
    Salt Lake City, UT
    80
    Default SSR board Cat5 cable distance?
    What is the typical allowable distance that an SSR board (triac based with optocouplers) can be located away from the controller board?
    I'm trying to put my design together using an Arduino as a controller with basic SSR boards distributed to the various controlled circuits locations as I have pretty good power distribution already. Using 8 channel SSR boards with RJ45 connectors and connected using Cat5 cables back to the controller, how far away can I put my SSR boards?
  2. Likes m00dawg liked this post
  3. #2
    Sep 2016
    15
    Default Re: SSR board Cat5 cable distance?
    I have tested 50' and it's working fine.... not sure how far you need to go
  4. #3
    Morrisburg, On, Canada
    2,540
    There is no "typical" standard distance.
    What you can find are members who have gotten say 50 ft in their situation. Past that you may find it works but it may become less reliable. It can also depend on factors like being near interfering power cables. But some may have experienced difficulties with 25 ft - so it depends on your situation, and the pulse frequency used for your SSRs.
  5. #4
    South Jersey
    2,026
    I had SSR's located about 125' -150' away from a Ren 64xc a couple of years ago. They worked fine.
  6. #5
    2,540
    That can be true for RS485. But for "TTL" type signals it isn't "typical". Ethernet drivers work for say 90 meters (300 ft). So there are means to go further but will require line drivers/receivers of some sort.
  7. #6
    3,717
    I have tested at 100' single CAT6 cable and it works fine.
  8. #7
    2,540
    Was there a limit to your PWM frequency? I'm thinking of what the narrowest pulse you could send with a 100 ft CAT6 cable and still have reliable dimming..
  9. #8
    3,717
    I have no issues with either the LED or incan lights and dim-ability. I do use the PWM mode (for led support) and very low light levels act the same on the long cable as they do on the short (3m) cables. I do not have any flicker on either.
