Results 21 to 30 of 37
Thread: Scheduler Instability
    Sep 2014
    arcadia florida
    84
    Default Re: Scheduler Instability
    been trying to get ahold of you.. your box is full.. have some questions for you.
    al
    Maryville, Illinois
    1,898
    According to those logs from earlier in December the sound system was running out of memory. It looked like it happened several times. I have not seen that one before, but the scheduler fixes I made would not address that. What are the specs on your machine? How many sequences are you running in the scheduler? Can you get me all of the logs from the logs directory when it happens again. For a crash dump, you can open the task manager and find the Vixen Administration process and right click on it. There is an option for create dump. It will make a big file as it will dump the memory contents for that process. It is best to do that when it hangs or stops functioning before you try to close Vixen or kill it. The dump will be big enough you will have to zip it and put it on dropbox or something. I know it is painful, but if you can get me this stuff it will help me better understand what is going on so I can fix it.
    Jeff
    Feb 2011
    Eagle Point, Oregon
    725
    Quote Originally Posted by kk4pvz View Post
    al
    Oops, never had that happen before. Thanks for letting me know, it's cleaned out now.
    Alex
    X3 Ren48LSD, X4 Ren16SS, X2 Ren24SS, X1 SRen32, FM-02, E1.31 Bridge
    X36 Super Strips, X9 Dumb RGB Mini Trees, ~25K lights (mostly LED)
    Pixel Mega Tree with 1600 pixels (4800 channels) run with an E682
    [IMG]http://i61.tinypic.com/2vaffhe.jpg[/IMG]
    Feb 2011
    Eagle Point, Oregon
    725
    Jeff
    Interesting....
    I bumped the schedule forward two hours today so I could capture some logs for you but it hasn't hung during the first go thru or ever since tonight which is a first since November. Last night I had inadvertently left the network line in to my home LAN, maybe that contributed to the problem. There's no changes I made other than a windows update that loaded this morning since the LAN was plugged in and the show computer had internet access. It rebooted last night too. I will post all the details you asked for tomorrow morning when I can access the scheduler again.
    Alex
    Sep 2014
    arcadia florida
    84
    well i have my show running. now working on 2015 but have alot of question about rgb and what alll i need.
    Feb 2011
    Eagle Point, Oregon
    725
    That's great Al!. Look forward to reading up with you in 2015!. Merry Christmas to your and the DIYC family!
    Alex
    Feb 2011
    Eagle Point, Oregon
    725
    Jeff, I experienced a hang when the schedule fired up tonight so I captured a dump file....but...erm...it's 1.8GB!. Gig with G!. Is that expected?? I haven't used drop box much yet, but assume that's too much to upload?
    BTW, MERRY CHRISTMAS VIXEN TEAM!!.
    Alex
    Maryville, Illinois
    1,898
    Yep that is normal. It is a full application memory dump. You will need Dropbox or something like that. Zip it up and that will compact it a bit.
    Feb 2011
    Eagle Point, Oregon
    725
    Alrighty then... I'll zip it up and upload tomorrow!.
    Alex
    Yuma, AZ
    1,600
    Hi:
    I gave up on the scheduler. I just load the sequence to be run, click on LOOP, hit F5 and forget about it until shutdown time, which is done manually.
    Merry Christmas.
    [B][I][U]Idun
