Results 11 to 20 of 37
Thread: Scheduler Instability
    Feb 2011
    Eagle Point, Oregon
    725
    Default Re: Scheduler Instability
    Thanks Jeff! I will replace these tomorrow, too late tonight. Also, tonight Vixen crashed when running the show for the first time. Here's a log that Window's offered after the event. Not sure if this helps any:
    Description:
    Stopped working
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: VixenApplication.exe
    Application Version: 3.1.66.2
    Application Timestamp: 54830a5d
    Fault Module Name: fmodex.dll
    Fault Module Version: 0.4.44.21
    Fault Module Timestamp: 5240fc2f
    Exception Code: c0000005
    Exception Offset: 0009ed84
    OS Version: 6.0.6002.2.2.0.768.3
    Locale ID: 1033
    Alex
    X3 Ren48LSD, X4 Ren16SS, X2 Ren24SS, X1 SRen32, FM-02, E1.31 Bridge
    X36 Super Strips, X9 Dumb RGB Mini Trees, ~25K lights (mostly LED)
    Pixel Mega Tree with 1600 pixels (4800 channels) run with an E682
    [IMG]http://i61.tinypic.com/2vaffhe.jpg[/IMG]
    SoCal
    206
    My scheduler would often hang and vixen will crash at seemingly random times, forcing me to end process the program and restart. But I think I may have found the issue. I turned off my computer's power saving options. I unchecked the "Turn off monitor" item and "Turn off hard disk" item in my Power Option settings today and it hasn't crashed once. It may be just luck so I'll keep an eye out for it in the next few days and see if this is really the issue.
    Feb 2011
    Eagle Point, Oregon
    725
    I have made some fixes recently to the scheduler to help with some of the stability issues in it. If you are willing to try it, here is a link to two dll's. You will need to replace Shows.dll and SuperScheduler.dll in the Modules -> App directory in the Vixen install. You can back the originals up in case you need to go back, but they need to be removed from the directory.
    https://www.dropbox.com/s/nysijoeyih...r-x64.zip?dl=0
    These are x64 versions. Let me know if you use the 32 bit for some reason.
    Jeff
    Jeff, I went to swap these out today but saw they are 64 bit, my show computer is 32 bit. Can you hook me up with that version? It seems like the problem is getting worse as my show has begun to hang on multiple songs now and not just on the first run through but randomly throught the night. UGH! I have a radio set up in the livingroom and we play the show in the background to make sure it is still running. I'd apprecitate any help you can give.
    Alex
    Maryville, Illinois
    1,885
    Give this a try. Has all my scheduler fixes rolled up into one.
    https://www.dropbox.com/s/p6iwh9z2ws...r-x86.zip?dl=0
    Jeff
    Feb 2011
    Eagle Point, Oregon
    725
    Will do tomorrow morning. Thanks do much Jeff!!
    Alex
    Feb 2011
    Eagle Point, Oregon
    725
    Unfortunately not a good report. Loaded it up tonight and at first seemed great. No hang on the first go through the set. But after about an hour Vixen crashed and froze. I restarted and it ran for another 45 minutes then hung in a random place. Then restated but again about an hour and a half later it froze...then again after another hour.
    People were texting us asking why the lights weren't running...we were listening to the radio but missed the shutdowns when we were watching a movie. Ugh!
    So I gave up and reverted back to the old dll files. Pretty rough night. Is there an alternate way to run the show?. I don't have a raspberry pi so I can't run the falcon pi player, right?
    Alex
    8,068
    xLights
    Set up xLights to match your controller configuration.
    Export the sequences to Vixen 2.1 format. note that the xLights rules may not be as flexible as the vixen display setup, so you may need to reorder your controllers for the export to make sure the channel order lines up.
    Import the exported sequences into xLights.
    Setup the schedule and play it.
    You can of course use the Vixen 2.1 scheduler too, but I hear most people prefer the xLights scheduler.
    Feb 2011
    Eagle Point, Oregon
    725
    Thanks Jon. Hmmm... Setting up another controller output seems like a lot of work and new things to learn= not so easy... But I'll take a look at xlights tomorrow.
    Alex
    Maryville, Illinois
    1,885
    Can you collect logs or in task manager right click on the process when it is hung a create a dump file for me. I need something to go on to see what is happening.
    Feb 2011
    Eagle Point, Oregon
    725
    Okay, sure! I've been trying..I see there's multiple options for log files in Vixen. I attached a few from awhile ago. And of these the right type, or should I be capturing it off the Task Manager? I haven't created a log file from there before but I just read up on it and will do so tonight!
    Attached Files Attached Files
    Alex
