Results 31 to 38 of 38
Thread: Outputs freezing and serious lag
  1. #31
    Taylor, Michigan
    831
    Default Re: Outputs freezing and serious lag
    posting to bookmark
    2012: First year, 104 renard channels
    2013: 280 Renard Channels, 1050 Pixel Channels (2 x E6804)
    2014: Going pixel crazy!
    [URL="www.strotherfamilychristmas.com"]www.strotherfamilychristmas.com[/URL]
  2. #32
    24
    thought that also Jon but if I run vix3 it doesn't happen or the1/4 chase or shimmer in the xlight test so cant be the hardware
  3. #33
    7,961
    I'm still leaning toward hardware. In the form of dmx line noise. It might not be the case. But that's where my technician gut is pointed given those symptoms.
    --Jon Chuchla--
  4. #34
    4,196
    Not true. Capacitance in the data line will cause problems as a function of the data pattern going through the signal wire. Some patterns may work fine, others may fail in unexpected ways. Moisture adds capacitance to the system.
  5. #35
    24
    you guys know better than me sounds like your talking Chinese it did snow than rain here
  6. #36
    24
    wanted to run the show so went back to vix3 scheduler and now so far running about 2 hrs with out any lagging or freezing keeping my fingers crossed
  7. #37
    Mar 2010
    Delaware, OH
    670
    vstar,
    When you played the Vixen2 file, did you have Vixen3 open on any computer that could access the same DMX universe? If so, that was the cause of your flickering. Vixen 3 sends a constant data stream of zeros when it is not playing a sequence
  8. #38
    24
    Quote Originally Posted by ebrady View Post
    vstar,
    no Ed ran into that problem once before and all the lights flickered this time just the ones in the first universe will check it again tomorrow
    ran the show tonight with vix3 scheduler and did not see any problems kept checking on it and didn't see any problems was a clear day today 35degrees maybe rain or the moisture was effecting it some how idont know but thanks again for every ones help hope it stays stable vixen 3 is great makes it so easy to sequence
    John
