Results 21 to 30 of 38
Thread: Outputs freezing and serious lag
    3,813
    Default Re: Outputs freezing and serious lag
    yes i am. Also happens on my win 7 machine.
    7,754
    I don't think we've seen this on win7 yet. I haven't been able to recreate it. I think Jeff and Ed have been trying too without success.
    3,813
    win 7 machine to a 7 port usb hub. 5 rs232 dongles going to px1s. all at 115k
    7,754
    Ugh. That sounds like a mess. We need to get you an sACN bridge!
    But nonetheless, it should work.
    -- Jon Chuchla --
    Mar 2010
    Delaware, OH
    670
    +1 !
    -- Jon Chuchla --
    Iowa
    95
    Quote Originally Posted by vstar View Post
    i am also having the same problems how did you convert your files in xlights cant figure it out want to give that a try see if it will run without lag or freezing
    thanks John
    I first converted my sequences out of Vixen 3.1u1 to vixen 2.1. Then I imported them into Xlights using the vixen 2.1 sequence file. You have to set up all your outputs in Xlights before you import them.
    Everything has been running great since I did this. I do like the Vixen program and want to continue using it. Very easy to program with.
    Kudo's to the development team!
    Mar 2010
    Delaware, OH
    670
    Martin,
    Can I get a copy of your profile to investigate with?
    Ed
    3,813
    thanks John
    I used the sequence export function. Exported to fseq (Falcon player format) and imported the result into xlights.
    Martin
    24
    thanks everyone for your help converted files started to test them and ran into a new problem I posted in nutcracker thread
    anyone have this problem or know how to fix it? converted my v3 sequence into .vix file I run the show all my rgb channels work fine but the dmx channels on the first universe 1-512 flicker they come on when they are suppost to during the sequence but when they are on they are flickering I then went to the test tab tested all channels samething happens except if I put it in chase 1/4 or shimmer then no more flickering weird any help would be much appreciated
    Thanks John
    ran Halloween show for 4 weeks no problems with v3 xmas show lags and freezes in v3 and in xlights the flickering problem
    thanks again for all the help I know everyone is busy with there own shows
    John
    7,754
    The flickering sounds like a hardware problem. Since it happens even on test mode it's likely a problem downstream of the computer. If I were you I'd start dividing and conquering on the wiring and controllers to see if there's a culprit out in the yard.
    --Jon Chuchla--
