Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Outputs freezing and serious lag
    Iowa
    95
    Default Outputs freezing and serious lag
    My outputs are freezing and having serious lag when running schedule.
    Windows 8.1
    Renard controllers
    San Devices 6802 and 6804
    Pentium I5 3.5 ghz
    8 GB ram
    Vixen 3.1u1
    Attached Files Attached Files
    7,750
    Default Re: Outputs freezing and serious lag
    How many controller channels?
    --Jon Chuchla--
    Iowa
    95
    --Jon Chuchla--
    12813 E1.31 and 304 Renard.
    3 usb to serial converters
    1 switch to 1-682 and 6 6804's
    7,750
    That's getting up there.
    Are you running your renards as Renard or dmx protocol? If you're running them as opendmx, that's one thing to try not to do.
    I assume you meant 8GB of ram. (Not mb). That's probably a bit shy for your channel count. It's Black Friday, I'd reccomend running out and buying more ram. That's a quick and cheap thing to do. Especially today! I'd recommend 16gb or more for your channel count.
    You definitely want to be running the x64 version of vixen. Are you?
    --Jon Chuchla--
    Iowa
    95
    --Jon Chuchla--
    I am running x64 and it is 8 GB of ram, darn fat fingers. I am running the renards as renard.
    208 going to one USB to serial converter, 96 going to another USB to serial, 48 going to another USB to serial.
    I have had it running four songs most of the night. Intermittent freezing.
    Maryville, Illinois
    1,609
    Can you make your profile available for me to take a look at? There are a bunch of weird errors in there that I would like to see what is going on. Those could definitely be related to the the issues you are seeing.
    Iowa
    95
    What files do you want and how do I send them to you?
    Maryville, Illinois
    1,609
    Your whole Vixen 3 directory that contains the logs, sequences, etc. Zip it up. Do you have Dropbox or something like that? Or create a bug report at bugs.vixenlights.com and attach it there.
    Iowa
    95
    Here it is. This is after I ran the show last night for 3.5 hrs.
    https://www.dropbox.com/s/nfzzh95r8a...n%203.zip?dl=0
    Iowa
    95
    I have converted my sequences to X-Lights and everything works fine.
    I would rather use Vixen3 for the ease and simplicity of it but this will work for now.
