Results 1 to 6 of 6
Thread: Problem creating sequence with no audio...
    Framingham, MA
    517
    Default Problem creating sequence with no audio...
    Joe,
    I'm trying to create a sequence with no audio and I'm running into a few issue:
    1) If I start with an Image I created (so all my channels and such would be defined) and click "No" when asked if I have an audio file, HLS crashes.
    2) If I try to create a new sequence NOT from an image and then select "No" it doesn't do anything. If I try to add a channel, it says I need to Load and Audio file or state no audio is used. However, I cannot see where to state that no audio is used. I thought there used to be an item on the Audio menu for that, but I'm not seeing it anymore.
    Dan Kulp
    Huntsville, AL
    3,648
    Default Re: Problem creating sequence with no audio...
    You use the Process to create a new sequence.
    Third dialog in it ask if you are to use a song or no audio.
    Joe
    Framingham, MA
    517
    OK. Still have the crash if I hit "No" on the first dialog with create from image.
    Also, can you explain the point of the first dialog? I would remove that as it seems pointless and the message is confusing.
    Dan Kulp
    Huntsville, AL
    3,648
    I don't crash -- it's a simple return from a Windows function executed by a menu selection.
    Again -- I can not make it crash.
    Joe
    Framingham, MA
    517
    I just made it crash again. Hopefully the crash report is something useful for you.
    edit....
    Just realized I mistyped the first one. It's not the "first" dialog, it's the third. The one immediately after I select the image to use.
    Dan Kulp
    Huntsville, AL
    3,648
    I finally figured it was not the first.
    Release 24B released.
    Joe
