Page 27 of 27 FirstFirst ... 17252627
Results 261 to 263 of 263
Thread: Simple code for Arduino Uno/Mega. Up to 48 realy/SSR channels, with Random mode
  1. #261
    Southern California
    897
    Default Re: Simple code for Arduino Uno/Mega. Up to 48 realy/SSR channels, with Random mode
    Quote Originally Posted by yukonjoe74 View Post
    the above code is working great. i changes it to only 8 channels 34-41 for my singing face. i took out the random sequence but now when my vixen is off it just constantly repeats the test sequence over and over. how can i change the code to make it run the test sequence only once and then wait for a serial connection ? so the face will be off until needed?? any help would be greatly appreciated.
    Code:
    // This code was written by Victor Perez for doityourselfchristmas.com based on the code from Zparticle, Si_champion and Neil Tapp.
     // To adapt the code to your case, just change this top section, with the #define lines.
     // Includes the watchdog timer library
     #include <avr/wdt.h>
     // This sets how many channels will vixen be sending. Can be set to any number from 1 to 48 for Arduino Mega, and 1 to 18 for Arduino Uno.
     #define CHANNEL_COUNT 8
     // speed for the com port for talking with vixen. From 9600 to 115200. Use the same speed as set in Vixen.
    #define VIXEN_COM_SPEED 57600 // tried all baud rates, 9600 lagged, no difference observed between 57600 and 115200
     // Timeout waiting for serial input before going to random mode (in milliseconds).
     #define TIME_OUT 1000
     // If the relays turn On and Off opposite to Vixen sequence, change "#define MODE NOT_INVERTED" for "#define MODE INVERTED"
     #define NOT_INVERTED 0
     #define INVERTED 1
     // which pins control which channels
    // Mechanical relay channels
     #define CH01 34
     #define CH02 35
     #define CH03 36
     #define CH04 37
     #define CH05 38
     #define CH06 39
     #define CH07 40
     #define CH08 41
     int channels[] = {CH01,CH02,CH03,CH04,CH05 ,CH06,CH07,CH08};
     int incomingByte[CHANNEL_COUNT];
    int i = 0;     // Loop counter
    volatile unsigned long  timer_a = 0; // new line
    //setup the pins/ inputs & outputs
    void setup(){
      // enable the watchdog timer with a time of 1 second. If the board freezes, it will reset itself after 1 second.
      wdt_enable(WDTO_1S);
      // specifically for the UNO
      sei();
    // initalize PWM Channels / Pins
     for (i=0; i < CHANNEL_COUNT; i++){
        pinMode(channels[i], OUTPUT);
    // set all the realys to off to start with
    //kev edit
    if (MODE == NOT_INVERTED) {
      for (i=0; i < 24; i++){
        digitalWrite(channels[i], LOW);
    else  {
      for (i=0; i< 24; i++){
        digitalWrite(channels[i], HIGH);
      for (i=24; i < CHANNEL_COUNT; i++){
    else  {
        digitalWrite(channels[i],LOW);
     testSequence();
    // set up Serial according to the speed defined above.
      Serial.begin(VIXEN_COM_SPEED);
    void loop()
       if (Serial.available() >= (CHANNEL_COUNT+2)) {
         wdt_reset(); // resets the watchdog
         timer_a = millis (); // new line
         int uno = Serial.read();
         if (uno == 126){
           int dos = Serial.read();
           if (dos == 33){
             for (i=0; i < CHANNEL_COUNT; i++) {
                 // read each byte
    if (incomingByte[0] <= 127) {
            digitalWrite(channels[0], HIGH);
          else {
            digitalWrite(channels[0], LOW);
      if (incomingByte[1] <= 127) {
            digitalWrite(channels[1], HIGH);
          else {
            digitalWrite(channels[1], LOW);
      if (incomingByte[2] <= 127) {
            digitalWrite(channels[2], HIGH);
          else {
            digitalWrite(channels[2], LOW);
      if (incomingByte[3] <= 127) {
            digitalWrite(channels[3], HIGH);
          else {
            digitalWrite(channels[3], LOW);
      if (incomingByte[4] <= 127) {
            digitalWrite(channels[4], HIGH);
          else {
            digitalWrite(channels[4], LOW);
      if (incomingByte[5] <= 127) {
            digitalWrite(channels[5], HIGH);
          else {
            digitalWrite(channels[5], LOW);
      if (incomingByte[6] <= 127) {
            digitalWrite(channels[6], HIGH);
          else {
            digitalWrite(channels[6], LOW);
     if (incomingByte[7] <= 127) {
            digitalWrite(channels[7], HIGH);
          else {
            digitalWrite(channels[7], LOW);
     if (incomingByte[8] <= 127) {
            digitalWrite(channels[8], HIGH);
          else {
            digitalWrite(channels[8], LOW);
    // Random mode code. Random mode starts if no serial input has been received in TIME_OUT millisenconds
    //   else {
    //     wdt_reset(); // resets the watchdog
    //     unsigned long diff = millis() - timer_a;
    //     if (diff >= TIME_OUT) {
    //      timer_a = millis ();
    //       int random_a = 0;
    //      for (i=0; i < CHANNEL_COUNT; i++){
    //           random_a = random(0, 2);
    //           if (random_a == 0) {
    //             digitalWrite(channels[i], LOW);
    //           else {
    //             digitalWrite(channels[i], HIGH);
    //TEST SEQUENCE ACTUALLY WORKS THE SAME FOR ALL CHANNELS - TEST OUTPUT FOR 1-24 CHANNELS APPEARS NOT_INVERTED WHILE FOR 25-32 APPEARS INVERTED -- THUS ALL LOOK THE SAME
    void testSequence(){
       delay (500);
    else {
       delay (500);
        wdt_reset();
        delay(500);
    else {
        wdt_reset();
        delay (500);
    First of all, IMO, you should not be using the code listed above that has already been modified by LateralLiz. She had a specific need for the modified code that you do not. I suggest going to post #1 and use the code there. Then if you do not want Random lights when Vixen is not running, then try commenting out the two digitalWrite statements in the Random section (don't comment out the whole section).
    Kevin
  2. #262
    Nov 2014
    11
    I Tried the first page code but did not work lights were on all the time. so the code by LeteralLiz works great except if there is no signal from computer it loops the self test over and over again. I also tried what you suggested about commenting out just the digitalwrite lines out of the random code but I still get the same looping test result.
    Does anyone know how i can modify this code to prevent the constant repeat of the test procedure all day? i only want test to run once and then wait for computer signal or show to start?
    here is my current code
    Code:
     #define INVERTED 1
     #define CH01 34
     #define CH02 35
     #define CH03 36
     #define CH04 37
     #define CH05 38
     #define CH06 39
     #define CH07 40
     #define CH08 41
    void setup(){
      sei();
    //kev edit
    else  {
    else  {
     testSequence();
    void loop()
         if (uno == 126){
           if (dos == 33){
                 // read each byte
          else {
          else {
          else {
          else {
          else {
          else {
          else {
          else {
          else {
       else {
           int random_a = 0;
               else {
       delay (500);
    else {
       delay (500);
        wdt_reset();
        delay(500);
    else {
        wdt_reset();
        delay (500);
  3. #263
    Oct 2019
    SoCal
    55
    Code:
     #define INVERTED 1
     #define CH01 34
     #define CH02 35
     #define CH03 36
     #define CH04 37
     #define CH05 38
     #define CH06 39
     #define CH07 40
     #define CH08 41
    void setup(){
      sei();
    //kev edit
    else  {
    else  {
     testSequence();
    void loop()
         if (uno == 126){
           if (dos == 33){
                 // read each byte
          else {
          else {
          else {
          else {
          else {
          else {
          else {
          else {
          else {
       else {
           int random_a = 0;
               else {
       delay (500);
    else {
       delay (500);
        wdt_reset();
        delay(500);
    else {
        wdt_reset();
        delay (500);
    Have you checked if the baud rate in your code matches the baud rate you have set in Vixen/Xlights/FPP/etc.?
