Page 29 of 29 FirstFirst ... 19272829
Results 281 to 287 of 287
Thread: Simple code for Arduino Uno/Mega. Up to 48 realy/SSR channels, with Random mode
  1. #281
    Nov 2015
    46
    Default Re: Simple code for Arduino Uno/Mega. Up to 48 realy/SSR channels, with Random mode
    The code in general has a major flaw. It does not have any header processing and will often not do what you expect.
    I totally agree. Last night the show ran fine without any issues. There were no power bumps since, and tonight nothing. It will not run the relays. I tried to reload the sketch. I tried to reload the Mega and the PI in different ways. I tried just about every trick in the book and it will not work with the show. it i unplug it from the PI I get the random mode working and turning the relays on and off. so frustrating. I really need a different controller for the AC strings, but I have no idea what to get and I'm already set up with the relays.
    I should mention that the pixel work flawlessly, not one issue
    How would I know if the controller was the issue? The reason i'm thinking it's the code is that it work fine in random mode.
  2. #282
    4,571
    You just need a better sketch. A lot of people grab this sketch and another from Victor. They both have the same major flaw and should be avoided. You need to find a sketch that supports Generic Serial header processing. The code in the thread below uses a three byte header with the third byte telling the code how many channels to process.
    http://doityourselfchristmas.com/for...+Serial+header
  3. #283
    Nov 2015
    46
    Thanks I'll look it up.... and i just rebooted the PI again and the Relays/Mega are working again. I'll go look up this new code and try it tomorrow night. Thanks!!!!
  4. #284
    Nov 2015
    46
    this code?
    Code:
    The purpose of this code is to allow the Arduino to use the
    generic serial output of vixen lights to control 5 channels of LEDs.
    Author: Matthew Strange
    Created: 14 October 2010
    Modifier: Ben Towner
    Modified: 19-OCT-2010
    Changes: Addition of 20 Digital On/Off Channels - Setup for Arduino Mega 2560
    // PWM Output - ChanX=PWM Pin
    int Chan1 = 2;
    int Chan2 = 3;
    int Chan3 = 4;
    int Chan4 = 5;
    int Chan5 = 6;
    int i = 0;     // Loop counter
    int incomingByte[5];   // array to store the 5 values from the serial port
    //setup the pins/ inputs & outputs
    void setup()
      Serial.begin(9600);        // set up Serial at 9600 bps
      pinMode(Chan1, OUTPUT);   // sets the pins as output
      pinMode(Chan2, OUTPUT);
      pinMode(Chan3, OUTPUT);
      pinMode(Chan4, OUTPUT);
      pinMode(Chan5, OUTPUT);
    void loop()
    {  // 5 channels are coming in to the Arduino
       if (Serial.available() >= 5) {
        // read the oldest byte in the serial buffer:
        for (int i=0; i<5; i++) {
          // read each byte
          incomingByte[i] = Serial.read();
        analogWrite(Chan1, incomingByte[0]);   // Write current PWM values to LED pins
        analogWrite(Chan2, incomingByte[1]);
        analogWrite(Chan3, incomingByte[2]);
        analogWrite(Chan4, incomingByte[3]);
        analogWrite(Chan5, incomingByte[4]);
  5. #285
    4,571
    No. that is even worse. It uses analog output to control the relays. Relays are not analog devices.
  6. #286
    Nov 2015
    46
    Default Re: Easy to use code for Arduino Uno/Mega. Up to 48 channels, with Random mode
    I looked through the whole thread but i didn't see anything else but the victor code.
    Sent from my SM-G960W using Tapatalk
  7. #287
    Southern California
    1,049
    Many people use the VictorPV sketch and it has proven to be reliable. It does look for a header (~!) to signal the beginning of the data stream. I am glad to hear that it started working again.
    Kevin
