Results 1 to 8 of 8
Thread: BUG: The "Modify This Effect" dialog refuses to appear
    Sep 2012
    Seattle, WA
    630
    Default BUG: The "Modify This Effect" dialog refuses to appear
    To reproduce this bug, try this:
    1. Group select a section of your timeline.
    2. The "Modify This Effect" Dialog box will appear.
    3. Press CANCEL.
    After you cancel this dialog box it will no longer appear. Restarting HLS will fix the problem. If you actually modify the effects and press OKAY, the dialog will continue to appear. The problem only happens if you CANCEL the dialog box.
    -=Steve
    Huntsville, AL
    3,648
    Default Re: BUG: The "Modify This Effect" dialog refuses to appear
    Hit the ESC key.
    Joe
    Aug 2012
    Nova Scotia, Canada
    1,798
    Quote Originally Posted by szaske View Post
    3. Press CANCEL.
    -=Steve
    I can confirm this.....
    I tried same and ESC will exit selection box but even if you select another area of sequence and hit modify this effect, it will not come up.
    This only happens as Szaske says, if you hit Cancel. If you actually do modify the effect thing work as expected.
    Austin, TX
    47
    This is what I was talking about in this thread yesterday: http://doityourselfchristmas.com/for...ffects-In-Mass
    6,737
    Correction ...
    There is a bug , after several times of selecting either a PP or a single effect
    and making the desired modification the dialog fails to respond .
    my appologies for not testing multiple times .
    Aug 2012
    Nova Scotia, Canada
    1,798
    There is no bug , think about your actions before you post a bug report !
    modify this effect = singular
    It works perfectly .
    If you are selecting a group , try GROUP as the operator in your quest .
    I don't think I get what you are saying...
    What Szaske reported is accurate.
    Select a single effect and right click to get the option "Modify this Effect" and click.
    Then Hit Cancel.
    Hit ESC
    Select another effect and right click, click "Modify this Effect".
    No box comes up to make any changes....You can't modify effects for any further selections.
    Huntsville, AL
    3,648
    Had an IN-Process flag that was not cleared with Cancel
    Version 23X released.
    Joe
    Austin, TX
    47
    Many thanks, Joe!
