Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Slow show not sure if a bug
    242
    Default Re: Slow show not sure if a bug
    So you put in the serial number from it in hls?
    Huntsville, AL
    3,648
    Yes
    6,688
    older tut that may help for selecting dmx dongles etc.
  4. Likes JHinkle liked this post
  5. #14
    242
    Ive ordered the dongle Joe suggested as well as the db9 to wire to my renards. Amazon said it will be here tomorrow so we shall see.
    Thansk for the help guys. I was starting to think i needed to use my macbook for the show!
  6. #15
    Huntsville, AL
    3,648
    You should run my debug report just to verify timing from the COM really is the issue.
    The OUTPUT process where yo identify which Universes are to be Outputted ===> Upper right corner -- check box to start debug file.
    The Play the OUTPUT .... when you start to see a lag -- stop the PLAY and go in and UNCHECK that box -- unchecking closes the file.
    Look in your sequence folder and there will be a debug text file -- open it with Wordpad.
    Every tic is time stamped so you can see processing time.
    Check the delta time for the COM call as THAT is what is suspect -- but we are only guessing without the facts.
    Joe
  7. #16
    242
    Ive ran the show now 2 nights with no problems at all.ive also tried running on rs232 but was unsucessful so imma leave it alone while its running and see if i can get it over to rs232 in the off season
