Results 1 to 10 of 16
Thread: Slow show not sure if a bug
    213
    Default Slow show not sure if a bug
    Not real sure if its a bug.
    Im using a intel core duo 2 laptop with a fresh install of windows 7.
    About 2 hours into my test show the show slows down. As in out of sync with the music and flashing light.
    I can restart hls and it will go right back to normal.
    Ive just had this happen tonight so i know its in this computer.
    Huntsville, AL
    3,644
    Default Re: Slow show not sure if a bug
    Check to see what else is running on the computer.
    HLS has Audio and Lights locked insync -- they can NOT get out of sync or lag from HLS's viewpoint.
    Your computer is responsible for delivering the transmission packets after being handed off by HLS.
    Your drivers may be lagging for some reason.
    You can always ask HLS to run a debug file -- it will time stamp each tic's operations.
    If you are running COM -- as in riving a renard via a COM port --- I have seen COM ports delay as much as 60 to 80 millisecs. If your tic rate is 25 or 50 millisecs -- then you will start to delay.
    That is one reason why HLS does not like COM -- do a USB to COM interface if you are using COM.
    Get a FTDI USB to COM device -- $10 on Amazon.
    HLS talks directly to the dll -- no Windows involved.
    Joe
    Huntsville, AL
    3,644
    What Transport media are you using --- E131, USB, COM?
    213
    Ok. Which one do u like the best?
    Im useing a usb to 485 now. But its using a fake com 7.
    Ive looked at the cou usage and the mem usage while running and its nothing. This machine aint even connectd to the net. Just for the show only so theres nothing on it to run. Just a fresh instal of window 7 and i did download all the updates and such but i have the wireless disabled.
    Thanks for your time and effort and dedication to such a great program!
    Huntsville, AL
    3,644
    How are you asking HLS to perform the transmit process -- using a COM port or a USB device?
    As I've stated -- I have seen Window's COM process take very LONG times to complete. HLS can NOT continue processing until the Window's COM call returns.
    The Window's fake COM to USB drivers are just a way of letting Windows applications still deal with COM Ports and not worry about the real USB interface.
    The COM to USB driver --- might NOT be one from Microsoft but from a third party --- and may not be performance aware.
    For performance purposes -- have HLS talk to the USB device (FDTI device) --- much better thru put!
    Joe
    213
    Gotcha.
    So i select usb renard instead of com.
    Im using a usb straiggt to 485 adapter
    Huntsville, AL
    3,644
    You got it ... try the USB instead and see if you still have the delay.
    Are you using Renards?????
    Don't select Renard unless that is the controller you are talking to since they have there own protocol.
    Joe
    213
    I am. 4 renards. One tr-24 and the rest ss24.
    When i do select usb-dmx it asked for a serial number?
    213
    What dongle do you suggest? Ill order the right thing
    Huntsville, AL
    3,644
    This is what I purchased from Amazon.
    I use the FTDI dll with this and it works great.
    Joe
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
