Results 11 to 20 of 30
Thread: Kudos to Conversion Writer
    7,939
    Default Re: Kudos to Conversion Writer
    An editor is what we call the module that edits a sequence. The new sequence, and open sequence buttons invoke "editors". The main v3 editor is the TimedSequenceEditor. But other editors exist too, there's the script editor. The v2 importer is another editor. You can't actually edit your v2 sequence with it, but it opens a file type, and somehow works with it. The v2 import editor just opens v2 sequences and gives you the wizard to convert it to a v3 sequence. So this error is related to either your v2 import editor part of the program being broken or missing, or that it can't open this particular file.
    -- Jon Chuchla --
    2,752
    I just downloaded and re-installed V3.1u1. Still have the problem after the re-install.
    2,752
    Made a copy of the sequence.
    Went into V2 and flattened the sequence.
    Started V3 and tried to open the sequence.
    Immediately got the editor message.
    Interesting.........
    7,939
    I'm not a v2 expert. I'll try to round up someone more experienced for you. MartinMueller might be a good guy to PM.
    -- Jon Chuchla --
    2,752
    Thank you.
    Broken Arrow, Oklahoma
    631
    Make sure that when you select open sequence you change the file type to Vixen 2.x sequence. We use this to determine which editor to use.
    [SIGPIC][/SIGPIC]
    2,752
    Thanks for the reminder.
    If you are talking about the drop-down box in the lower right corner - I did.
    Still no joy.
    2,752
    In my last attempt, I copied the V2 sequence, V2 profile and the audio file (.mp3) to the sequences directory of the V3 profile in use.
    Still receive 'Can't find an editor to open this file type. ("LWW Amazing Grace.vix")'
    Update:
    In an attempt to make this happen, I have done the following as well -
    Downgraded the V3 version to 3.0.10 (64 bit). No joy.
    Downloaded and reinstalled a new copy of V3.1u1 (64 bit). No joy.
    Removed all un-needed software from the computer (looking for conflicts). No joy.
    Attempted this on three (3) different computers. You guessed it - No joy.
    2,752
    Is it possible to build the channel mapping cross reference manually?
    Like using a text editor or the like?
    7,939
    Do not downgrade from 3.1 to 3.0. It will break your 3.1 installation. And a reinstall won't necessarily fix it.
    Have you been able to reimport any v2 sequences that you've previously imported successfully? If that works we can rule out a problem with your v3 installation.
    --Jon Chuchla--
