Let me know if you need other info.
Here are the results:
1. Created new blank sequence called Watt Meter
2. Attached profile (Also tried it without profile attached)
3. Setup all channels in Watt Meter
4. Saved new sequence
5. Tried to just copy loadable data
6. Got the following question:
This change requires that events are to be truncated in order to maintain data integrity. This will cause data loss in the destination sequence. Proceed?
I have tried both Yes and No
7. The following error occurs and no data is copied.
Divide by zero
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.DivideByZeroException: Attempted to divide by zero.
at Vixen.CopyDataDialog2.buttonCopy_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Vixen
Assembly Version: 2.0.7.0
Win32 Version: 2.0.7.0
CodeBase: file:///C:/Program%20Files/Vixen/Vixen.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
fmod
Assembly Version: 2.0.5.1
Win32 Version: 2.0.5.1
CodeBase: file:///C:/Program%20Files/Vixen/fmod.DLL
CometConversion
CodeBase: file:///C:/Program%20Files/Vixen/AddIns/CometConversion.DLL
DMXAddIn
CodeBase: file:///C:/Program%20Files/Vixen/AddIns/DMXAddIn.DLL
MIDIReader
CodeBase: file:///C:/Program%20Files/Vixen/AddIns/MIDIReader.DLL
Prop1SeqGen
CodeBase: file:///C:/Program%20Files/Vixen/AddIns/Prop1SeqGen.DLL
Prop2SeqGen
CodeBase: file:///C:/Program%20Files/Vixen/AddIns/Prop2SeqGen.DLL
RemoteClient
CodeBase: file:///C:/Program%20Files/Vixen/AddIns/RemoteClient.DLL
RGBLEDAddIn
CodeBase: file:///C:/Program%20Files/Vixen/AddIns/RGBLEDAddIn.DLL
Spectrum
CodeBase: file:///C:/Program%20Files/Vixen/AddIns/Spectrum.DLL
WattMeter
CodeBase: file:///C:/Program%20Files/Vixen/AddIns/WattMeter.DLL
Waveform
CodeBase: file:///C:/Program%20Files/Vixen/AddIns/Waveform.DLL
FrameGenerator
CodeBase: file:///C:/Program%20Files/Vixen/Plugins/UI/FrameGenerator.DLL
Frames
CodeBase: file:///C:/Program%20Files/Vixen/Plugins/UI/Frames.DLL
LedTriksUI
CodeBase: file:///C:/Program%20Files/Vixen/Plugins/UI/LedTriksUI.DLL
StandardScript
CodeBase: file:///C:/Program%20Files/Vixen/Plugins/UI/StandardScript.DLL
ScriptEngine
CodeBase: file:///C:/Program%20Files/Vixen/ScriptEngine.DLL
StandardSequence
CodeBase: file:///C:/Program%20Files/Vixen/Plugins/UI/StandardSequence.DLL
TriggerResponse
CodeBase: file:///C:/Program%20Files/Vixen/Plugins/UI/TriggerResponse.DLL
AppUpdate
CodeBase: file:///C:/Program%20Files/Vixen/AppUpdate.DLL
ICSharpCode.SharpZipLib
Assembly Version: 0.85.1.271
Win32 Version: 0.85.1.271
CodeBase: file:///C:/Program%20Files/Vixen/ICSharpCode.SharpZipLib.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
