Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: HLS - Marine Snipper Hit Bull with Beat Track and Piano Notes
    Huntsville, AL
    3,644
    Default Re: HLS - Marine Snipper Hit Bull with Beat Track and Piano Notes
    Donny --- can you post the 1.5sec FFT using 22E --- I'd like to see how the better resolution affects your display.
    Thanks.
    Joe
    Huntsville, AL
    3,644
    Another thought --- I'm going to remove the "Remove Vocals" as default.
    As I stated in the video --- I subtract R from left to remove vocals -- BUT it will also remove (or partially remove) and instrument that appears in both channels producing frequency components NOT in the song but produced by the subtraction process --- each channel has same freq but they are phased shifted from each other producing the artifact when subtracted.
    Matter of fact ... I'm going to remove it altogether .... I think it will cause more confusion than benefit.
    It will be gone in the next release.
    Joe
    Jan 2011
    Ocean Springs MS
    1,004
    Thanks.
    Joe
    Huntsville, AL
    3,644
    Thanks -- I like it better.
    Joe
    Huntsville, AL
    3,644
    Let me explain some things about what the FFT is telling you:
    It says --- this is a frequency where there is energy.
    Take a guitar string that produces a fundamental frequency of 82hz.
    Will you expect to see 82hz throughout your sequence --- NO.
    Any string instrument will produce a note where the frequency being generated varies ... lets say an an example --- 78 to 86hz for the guitar string above.
    Mostly it vibrates at 82 -- but actually the distribution is from 78 to 86 hz.
    The other thing to realize is that the frequency will change based on temperature and humidity.
    At the start of a song --- a piano note may be at 443 hz --- at the end of the song it may be at 451 hz due to being beaten to death during the song and getting warmer than at the start.
    THOSE shifts in frequency --- due to the nature of vibration (say 78 to 86 above) and shifts due to change in temperature can cause your your DSP bandpass to NOT be centered throughout the song --- thereby giving a LOWER envelope profile at some points in the song.
    You can attempt to resolve that by properly setting the DSP ORDER (or Q) of the filter AND the Bandwidth setting.
    The Bandwidth says ... How Wide the filter is centered around the center frequency selected.
    As an example ... lets say there are 2 frequencies of interest --- one at 300 and one at 350 hz
    If you set a Bandpass center freq at 300 and a bandwidth of 100hz --- the 350 is actually in the filters acceptance window. How much of that 350 is going to get thru --- that will depend on the ORDER or Q.
    If the ORDER or Q is 1 --- that is a simple 3db rejection at the edge of the filter's skirts --- 250 to 350. That 350 signal WILL get through
    If the ORDER is 5 --- then there will be approximately 5 * 3db or 15 db of rejection --- THAT is a lot --- so little will get thru.
    The other thing about the FFT that you need to be aware of is HARMONICS.
    All instruments produce a note that contains the fundamental frequency BUT there are also many harmonics frequencies (mostly ODD harmonics) also generated.
    If the note was produced by a 100hz SQUARE wave ... the FFT will show energy at 100, 300, 500, 700, 900, 1100 hz ....
    THOSE frequencies are NOT different notes or different instruments --- those harmonics are what give the note its quality. The same note played on a piano, guitar, violin will each have a different distribution of harmonic frequencies -- its what makes them sound different.
    There are some instruments where the energy of a harmonic is actually higher than the energy of the fundamental frequency you are trying to find -- beware.
    The LOW PASS filter option in the FFT is there to help remove the harmonics and let you focus on the fundamental frequency.
    Using that square wave example above ... fundamental freq of 100hz but the FFT whose BLIPS at 300, 500, 700 ....
    Set the LowPass Filter at 400hz and all of those harmonics will disappear from the FFT display.
    Do a google search on FFT, musical notes and harmonics, DSP, BandPass filters --- there is a ton of information out there.
    Knowing how to properly interpret what the FFT is telling you and then how to use that information to set your DSP Bandpass filter properly will allow you to quickly pull out any instrument being played in a song.
    Hope all of this technical stuff helps.
    Joe
    Huntsville, AL
    3,644
    Quote Originally Posted by Donny M. Carter View Post
    I was able to duplicate a few times Joe.
    I think I see the issue.
    You are selecting a channel to drop the envelope generated effects on but THAT channel is NOT currently in the Display Group.
    Hence the channel is NOT available to attach an effect to --- ERROR.
    I will modify the Envelope Profile channel select to ONLY be those channels in the display group.
    That should keep others from doing the same thing.
    If that is NOT the root-cause for the issue --- let me know.
    Joe
    Huntsville, AL
    3,644
    HLS 22G -- Prevent Non-Display Group channels from being used -- thereby addressing the issue.
    Thanks.
    Joe
    Jan 2011
    Ocean Springs MS
    1,004
    Joe
    I guess the issue was the music file! I tried it on a second computer and it did the same thing. I got a different version of the song and it works fine now. Did you change anything when selecting the channels in the FFT box? I have to select channels in both the select channel tab and in the upper channel bar to have the effect appear in the track. Thanks Joe!
    Huntsville, AL
    3,644
    Yah .......
    Missed an area in the 22G change -- fixed in 22H.
    Anyone using 22G --- get off it NOW if you are using the Envelope Profile. The process is writting to the wrong channel!!!
    Get on 22H!!!!!
    Joe
  10. Thanks Boof63 thanked for this post
