Results 21 to 30 of 32
Thread: HLS - Auto-Generate your Beat Track
    Feb 2012
    Kadina,South Australia,Australia
    484
    Default Re: HLS - Auto-Generate your Beat Track
    HI Joe am running 22M and having problems with the Envelope Profile Dialog Box. I can select and enter the values and select the channels. However I can not select RGB Box (it vanishes as you move cursor over it).
    Also select then channel button on bottom left of dialog box calls up the 'Select a Channel' box but it is empty- no channels at all in it. Also save profile sometimes works and other times just does nothing when selected.
    Cheers Boof63
    Ps tried on existing sequence using some candles-segments that weren't being utilised in the song. No luck. Tried fresh song (Music Box Dancer) and tried my working matrix (thanks for that) but same problems, sorry.
    Key West, FL
    3,637
    You need channels other than a PP in the design grid.
    The process works --- take a hard look at what you are doing --- I suspect you have no channels showing on the Grid.
    Joe
    Feb 2012
    484
    is there anyway to use segments for displaying the vdu output?
    or does it all have to be individual rgb pixels?
    cheers Boof
    Key West, FL
    3,637
    My video did not use RGB Pixels -- it used incans or leds.
    You can use Segments.
    Joe
    Feb 2012
    484
    OK still no luck, using rgb's, video attached explains - I hope.
    Using segments or individual pixels has same result.
    cheers Boof63
    Here is link in dropbox to video, cheers again
    https://www.dropbox.com/s/vinacsx3cm...20joe.mp4?dl=0
    Nov 2013
    Blane, Mn
    159
    Boof I just tested in 22N and built a RGB viewmaster if you put your pointer on the R G B or channel to include rgb channels and click it will include your rgb channels so you can select your default channel or segment, yes if you place the pointer over the selection box it disappears in 22 N, again just place the mouse cursor over an area as I indicated and youll be able to include RGB channels for your default
  7. Thanks Boof63 thanked for this post
    Likes Boof63 liked this post
  8. #27
    Key West, FL
    3,637
    The disappearing RGB was a Halloween Ghost that stop in early to have some fun.
    Marshmallow Man scared him away -- so he is gone in Version 22P.
  9. Thanks Boof63 thanked for this post
  10. #28
    Nov 2013
    Blane, Mn
    159
    Joe your a machine..........I know you were a Marine but do you ever sleep? Thanks for all you do!!
  11. #29
    Feb 2012
    484
    THanks joe works well now , one small glitch maybe, once you have saved a profile and then reloaded it, selecting save again appears to either overwrite the original or do nothing,
    as the save dialog box doesn't appear at all
    Otherwise works a treat thanks
    cheers Boof63
  12. #30
    Key West, FL
    3,637
    It over-writes and saves what you have shown.
    I see buttons all the time -- I don't see what you are saying.
    Joe
