Results 1 to 5 of 5
Thread: Ability to decide what PP effect to include in preview
    Jan 2013
    270
    Default Ability to decide what PP effect to include in preview
    Hi Joe,
    After long break from my x-mas lights I am about to slowly start to bug you again.
    Once again thank you very much for your help and support with HLS last year. Thanks to you I was able realize my vision. In case you have not seen my display ... here it is: https://www.youtube.com/watch?v=LWfcfL6KUXo
    THANK YOU, THANK YOU, THANK YOU .....
    Here is my new enhancement request which I have on my mind since I finished sequencing my first song last year.
    During sequencing we do a lot of previews to see our result. As I was adding more and more effects to my show the preview compiling took longer every time. I found out it became worse after adding more pixel-plane effects (HLS native/none native) to my sequence. My remedy for that was not to keep them in the sequence when I worked on it. I had to have a separate XLS spreadsheet with all the effect details (length, intensity, position, effect type, all it's settings, etc...) After I was done with other sequencing I had to put them back (over 20 minutes work). Then do the whole compile. If I needed to make any change in my sequence I had a dilemma: to remove them and apply them again later on or go through the painful slow compiling during previews when trying to implement the change/fix. (FYI: finished song preview compile took over 5 minutes). Honestly I wasted bunch of hours just because of these effects and their impact on the HLS.
    My enhancement proposal to avoid this issue in future: Make HLS smarter to exclude these PP effects during preview. Lets say to have a check box on the effect by itself and let the user decide what PP effect should be compiled during preview. Like this:
    This would be a huge help for us working with 10K+ pixels or people using more PP effects.
    What do yo think?
    Huntsville, AL
    3,646
    Default Re: Ability to decide what PP effect to include in preview
    A good friend, Al, sent me a wish several months ago --- I have not implemented it.
    Al's request would cover yours.
    Al requested to have an option to only compile and Preview only those channels that are on the sequence grid --- since those are most likely the ones you want to look at.
    You have worded your request in a way that makes sense to me. I've been delaying in implementing my Al's request because I could no fully see/understand the benefit.
    I'll do that as life gives me time.
    I'm in AL for the summer. I have had a mill/lathe combo in my garage for 6 years now and don't know how to use them --- So I'm taking a 10 week Machinist class at the Community College to learn how to operat both a mill and a lathe. My end goal is to make some custom 3D print heads for a high precision 3D printer I'm designing.
    Ran my first mill tonight - made chips!!!.
    So as time comes free --- I'll get it implemented.
    Joe
    Jan 2013
    270
    Wow. .. you are a busy man.
    Thank you Joe for the future implementation.
    Good luck with your 3D printer heads project.
    Huntsville, AL
    3,646
    Check Version 19T.
    I think it will do what you are looking for.
    Only Previews what is in the active sequence editor's grid space.
    Also -- no master or sub lighting channels.
    Let me know --- I quick tested and all looked ok.
    Joe
    Jan 2013
    270
    Thank you Joe.
    I'll give it a whirl over the weekend.
